engine and gearbox removal
- Dave cc
04 Nov 2012 08:36 - 04 Nov 2012 08:38 #52196
by Dave cc
Replied by Dave cc on topic engine and gearbox removal
Yes mate all the same bloke on ebay flogs them as well good bit cheaper than ORA
or a 2nd hand 1 for £35
Item number 150933532155
Last edit: 04 Nov 2012 08:38 by Dave cc.
- nate78
04 Nov 2012 16:22 #52234
by nate78
Replied by nate78 on topic engine and gearbox removal
i saw them, at that price it will be silly not to use one, started prepping the jimny engine for removal, just the fuel lines, gearbox bolts and engine mounts to remove then it will be coming out, will wait till the 16v block arrives so i can clean it before adding parts.
- Dave cc
04 Nov 2012 21:17 #52318
by Dave cc
You will need a 1600 16v cam cover and belt
- nate78
07 Nov 2012 09:07 #52547
by nate78
as the 16v belt is wider would i need to change the cam gear/cog too?
- Dave cc
07 Nov 2012 10:22 #52555
by Dave cc
Nope was fine with the standard jimny top belt pulley
- nate78
07 Nov 2012 10:28 #52556
by nate78
thanks again dave, hope fully this weekend i will be pulling the jimny engine and swapping everything over, i think i have everything i need other than the mount but i will fabricate something the weekend when i dry fit the block back in, i am hoping that the sump will clear with the 1.5 inch lift.
Time to create page: 0.283 seconds
