Panhard fouling steering arm
  • Paul4x4
06 Oct 2012 20:32 #49639 by Paul4x4
Replied by Paul4x4 on topic Panhard fouling steering arm
Smoggy wrote: Marky your an absolute revelation and that well and truly deserves a thankyou, it might just work :)
I hope you can make it work that way with just some minor adjusting. :)
And you truck looks awesome btw, good job Smoggy! B)
  • Smoggy
06 Oct 2012 20:41 #49642 by Smoggy
Replied by Smoggy on topic Panhard fouling steering arm
Thanks mate I am pleased with the progress. Although it has probably taken me 5 times as long as it would you and Marky with my limited skills :laugh:
But it has been a good learning curve and I am glad I did it rather than buying a truck all done, even if it has cost me three times as much :)
  • markyp2000
06 Oct 2012 20:44 #49643 by markyp2000
Replied by markyp2000 on topic Panhard fouling steering arm
at least is done the way you want and you now every inch of it and if it breaks its your own fault lol and you now how to refix its and you never stop learning but would you do another build like this
  • Smoggy
06 Oct 2012 20:54 #49647 by Smoggy
Yeah definitely I would. I am quite anal when it comes to detail :)
Before modding it I removed every bit of rust by grinding back to bare metal then using rust converter to make sure. Followed by 2 coats of epoxy mastic paint and a spray with dinitrol underbody wax with dinitrol cavity wax for the box sections etc.
If I am spending all this money I want it to last.
  • blakey2000
07 Oct 2012 02:15 #49655 by blakey2000
Replied by blakey2000 on topic Panhard fouling steering arm
looks like an incorrect pitman arm if it was the right one why would it be longer(as in further out from the steering box) then the original? that would be changing how the steering works IE turn the wheel further before lock.
whose pitman are is it?
  • Smoggy
07 Oct 2012 08:26 - 07 Oct 2012 08:38 #49658 by Smoggy
Its a Jimnybits drop pitman arm supposed to be for big lifts, its not longer Blakey its just got a bigger kink/drop than the standard one.
Last edit: 07 Oct 2012 08:38 by Smoggy.
Time to create page: 0.207 seconds
