Panhard fouling steering arm
- Smoggy
07 Oct 2012 19:10 #49690
by Smoggy
Replied by Smoggy on topic Panhard fouling steering arm
I am looking to get a more condensed fitting than the tie rod to mount to my pitman arm. Does anyone know if there is a rose joint available for this fitting.
- markyp2000
08 Oct 2012 17:16 #49745
by markyp2000
Replied by markyp2000 on topic Panhard fouling steering arm
do you no what the tread size is and did you have any luck shaving down the panard rod coler
- Smoggy
08 Oct 2012 20:17 #49770
by Smoggy
Ive just left it for now Mark. Have refitted the exhaust and managed to start the car so must have connected the fuel lines up ok at least
My main problem now is power steering fluid pi**ing out of the high pressure connection to the steering box so will have to address this tomorrow. There is also a constant really bad screeching like fan belt slipping. The power steering res is being kept full and there is underseal on the fan belt. Any ideas mate. gonna change the fan belt and power steering belt tomorrow too as a precaution.
- markyp2000
08 Oct 2012 20:27 #49772
by markyp2000
did you put new seals on the pipe and id start with changing the belts then at least you no thay are new
- Smoggy
08 Oct 2012 20:38 #49773
by Smoggy
The pipe was a banjo connection to the steering box with a copper washer each side of the banjo. I reused the copper washers, might get 2 new ones of those as well to be on the safe side.
- markyp2000
08 Oct 2012 20:59 #49778
by markyp2000
yer there what i ment lol
Time to create page: 0.249 seconds
