Panhard fouling steering arm
- Smoggy
08 Oct 2012 21:09 #49779
by Smoggy
Replied by Smoggy on topic Panhard fouling steering arm
The old high pressure pipe was leaking so I got one from cam suzuki to replace it. The end that goes onto the steering box is slightly different to the one I had. The old banjo fitting had a flat cast on the end of the banjo, this one has a flat cast onto the pipe just before the banjo if that makes sense. When I remove the radiator tomorrow ( to do the belts) I will have to get a good close up look of where the banjo meets the steering box to ensure the flat is causing the banjo to not seat properly.
- Smoggy
04 Nov 2012 16:09 #52231
by Smoggy
Just done exactly as you suggested Mark and there is now a couple of mm daylight between them woohoo and now I dont have to mess about changing the drag link
markyp2000 wrote: on your panard rod did you get the cone spacers things could you not shave some off so it sits towards the back and then space it at the front with washers
- markyp2000
04 Nov 2012 17:15 #52240
by markyp2000
Replied by markyp2000 on topic Panhard fouling steering arm
cool that good to here
Time to create page: 0.251 seconds
