Slight engine squeak & clutch squeak
  • ZookFastback
30 Sep 2012 10:49 #49128 by ZookFastback
Replied by ZookFastback on topic Slight engine squeak & clutch squeak
No, not the cam tensioner pulley. I meant the one on the outside, just above the power steering pump...
[IMG
This is the one that I replaced on my G13BB engine.
  • markyp2000
30 Sep 2012 11:04 #49131 by markyp2000
Replied by markyp2000 on topic Slight engine squeak & clutch squeak
ZookFastback wrote: No, not the cam tensioner pulley. I meant the one on the outside, just above the power steering pump...
the pic if you read zookfastback he says it is on a twincam engine and thay dont have cambelts
30 Sep 2012 13:55 #49143 by facade
The rusty lump of metal in my photo is the power steering belt tensioner on a twin cam. (not VVT) It is actually an 88mm OD bearing that runs on the back of the power steering belt. To tension the belt, follow the directions in pink to move the whole pulley.
As to the original post, I suspect a slack belt, steering or alternator, which is now slipping because of dampness from the original splashing through water. The squeaky clutch is probably dirt on the cable end, or rust forming inside the clutch housing.
(At the risk of shouts of heresy, I avoid significant water, and especially muddy water: I'm too old now to fix the damage that it does)
  • J-Bro
30 Sep 2012 17:07 #49178 by J-Bro
Replied by J-Bro on topic Slight engine squeak & clutch squeak
I've just had it looked over by a mechanic friend.
Clutch is on its way out. When clutch pedal is down no noise, when up a squeak from a bearing.
Are they prone to go? Expensive? Only had it a week!
Thanks for all the replies!
30 Sep 2012 17:31 #49188 by facade
Do you mean a squeak like a little mouse sqikk sqikk =a dry pivot/cable
a squeal like a cat outside at midnight = bearing is shot /something is rubbing metal on metal
or a whirring rummbly sound = input shaft bearing or layshaft bearings in gearbox?
  • J-Bro
30 Sep 2012 20:04 #49218 by J-Bro
Like a mouse
But getting worse its defo to do with the clutch.
Noise goes when clutch engaged
Time to create page: 0.298 seconds
