How to fit a 2"or 3 spring lift.+Wiring spotlights
- GuardianAngel
04 Nov 2013 14:33 #89319
by GuardianAngel
Replied by GuardianAngel on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
Thanks for the info everyone
- Tommo
05 Nov 2013 23:28 #89573
by Tommo
Replied by Tommo on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
- Dean1994
06 Jan 2014 13:01 #99355
by Dean1994
Replied by Dean1994 on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
Hi I've just bought the same spot lamps as you, just wondering how you mounted the bar on the roof as I have a soft to Jimny too?
- Dean1994
06 Jan 2014 13:04 #99357
by Dean1994
Ahh just seen your link on how you mounted them think I will do the same cheers!!
- Lukeavb
23 Aug 2014 18:05 #122606
by Lukeavb
Replied by Lukeavb on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
Will I need new bolts for my 3" or can I re use the old ones
where can I get new bolts if I will need new bolts?
- Tommy-Boy
30 Mar 2016 17:43 - 30 Mar 2016 17:46 #164655
by Tommy-Boy
Replied by Tommy-Boy on topic spring lift.+Wiring spotlights
Hi Guys
could someone clarify that i'm understanding this correctly in regards to wiring a light bar onto my little Jimny
This is my understanding of the relay diagram as posted in this post from dirtydogz
www.bigjimny.com/index.php/forum?view=topic&catid=7&id=45978
I'm just not 100% that i am understanding the diagram correctly.
However the light bar is fitted and when hooked up to my jumper pack it burns your flippin eyes out!! LOL
- Negative (-) wire from the light bar to a sutibale earth point
- Pos (+) wire from the light bar to pin 87 on the relay
- Pin 85 on relay to "Acc" on the switch
- Pin 30 direct to the battery Pos (+) through a sutible fuse (15Amp)
- Pin 86 daisy chain to pin 30 with a second bridge wire to the negative (-) switch terminal, even though this is live (+) ?
- Pos (+) from the switch to the red wire on the headlight plug
Last edit: 30 Mar 2016 17:46 by Tommy-Boy. Reason: cant spell for shit
Time to create page: 0.196 seconds
