How to fit a 2"or 3 spring lift.+Wiring spotlights
  • jfkenpoman
18 Jan 2013 17:39 #58517 by jfkenpoman
dont suppose there is a video showing the fitting of the 2" lift kit B)
  • GWR
20 Feb 2013 19:25 #63396 by GWR
Hi guys, I am new to the forum and am in the process of fitting a 3" lift. I started at the rear, and fitting the extended brake line first then dropped the shocks and springs out. No problem so far :) then I came to fitting the relocation brackets they didn't fit :dry: the tube which is meant to fit to the original bracket was around 1cm to long on both sides! So I set about it first with my hacksaw then with the angle grinder. Has anyone else had this problem or did I receive the wrong ones? Anyway they are now on as are the springs and shocks, so far so good. Next job will be to fit the adjustable pan hard rod then begin the front end. Got some modular wheels with Sahara tyres on waiting for me too finish the lift :cheer:
  • dirtydogz
20 Feb 2013 21:22 #63442 by dirtydogz
Good to hear you got the relocation brackets to fit on your jimny in the end, and I hope my guide to how to fit a lift is helping you, best of luck with fitting the rest of the parts.
DIRTYDOGZ
  • GWR
21 Feb 2013 19:37 - 21 Feb 2013 19:38 #63543 by GWR
Your guide was very helpful thanks. I managed to get the rear end mostly done this afternoon although I still have the castor correction bushes to fit and I suspect that is going to be a tough job lol. I took it for a test drive to make sure the bikes were ok. No castor correction and without the steering damper fitted and it was scary :ohmy: the steering was appalling and I kept veering to the right! I won't t be driving it until the rest of the bits sre fitted, I don't think my nerves could take it.
Last edit: 21 Feb 2013 19:38 by GWR. Reason: Predictive text!
  • reaper
21 Feb 2013 20:24 #63552 by reaper
GWR wrote: Hi guys, I am new to the forum and am in the process of fitting a 3" lift. I started at the rear, and fitting the extended brake line first then dropped the shocks and springs out. No problem so far :) then I came to fitting the relocation brackets they didn't fit :dry: the tube which is meant to fit to the original bracket was around 1cm to long on both sides! So I set about it first with my hacksaw then with the angle grinder. Has anyone else had this problem or did I receive the wrong ones? Anyway they are now on as are the springs and shocks, so far so good. Next job will be to fit the adjustable pan hard rod then begin the front end. Got some modular wheels with Sahara tyres on waiting for me too finish the lift :cheer:
Any pics mate im strugleing to think how the brackets were wrong
  • Richard666
24 Jun 2013 21:25 #74976 by Richard666
How much did all that cost just trying to get some idea on how much it will cost to do 2" lift
Time to create page: 0.330 seconds
