How to fit a 2"or 3 spring lift.+Wiring spotlights
- Richard666
24 Jun 2013 21:26 #74980
by Richard666
Replied by Richard666 on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
That would be very useful
- dirtydogz
24 Jun 2013 22:07 - 24 Jun 2013 22:07 #74995
by dirtydogz
Replied by dirtydogz on topic Fitting a 2"or 3" spring lift.+ Wiring spot lights
Jimnybits 2"lift £336 +rear shock repos £30 + correction bushes £106.80.
www.jimnybits.co.uk/shop/jimny/suspension/cat_171.html
Last edit: 24 Jun 2013 22:07 by dirtydogz.
- GuardianAngel
28 Oct 2013 16:30 - 28 Oct 2013 16:32 #88337
by GuardianAngel
Replied by GuardianAngel on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
Last edit: 28 Oct 2013 16:32 by GuardianAngel.
- Jimnyash
29 Oct 2013 08:01 #88433
by Jimnyash
Replied by Jimnyash on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
That's the relay and as far as I know, it's a standard 5 pin automotive relay (at least that's what I asked for and got when wiring my spots).
- dirtydogz
03 Nov 2013 14:36 - 03 Nov 2013 14:52 #89156
by dirtydogz
Replied by dirtydogz on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
Sorry Guardian Angel I know it's a bit late, but as Jimnyash said, yes it is a wiring diagram of a relay.
If you buy a set of the ring spot light you will get a 4 pin relay and fitting kit in the box.
www.halfords.com/webapp/wcs/stores/servl...-1_categoryId_272451
Last edit: 03 Nov 2013 14:52 by dirtydogz.
03 Nov 2013 21:12 #89239
by jimkyx
Replied by jimkyx on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
4 pin is a single pole relay
5 pin is a change over relay
You can use a 5 instead of a four but not the other way round.
Best price for these relays is Maplin.
The following user(s) said Thank You: GuardianAngel
Time to create page: 0.197 seconds
