Body lift
- JimnyX19
07 Aug 2012 11:15 #45623
by JimnyX19
Body lift was created by JimnyX19
Orite guys my body lift has been delievered and hoping to get it fitted this week I've been reading some threads on here seems pritty straight forward bu just want to double check I have the other necessary parts , steering spacer, extended brake hoses? Think that's it , als will be fitting superpro caster camber correction bushes same time we I'll be ordering 3" susp lift shortly. Some people here are saying I have to bend 4wd gear stick leaver also but some have said they've got away with not doing it? Any more info before I start will appreciate and will upload photos while doing cheers nathan
- Smoggy
07 Aug 2012 13:47 #45630
by Smoggy
Replied by Smoggy on topic Re: Body lift
You might need to get a dropped pitman arm for your steering box at the same time? Not 100% sure but I needed one for my 2'' body and 4.5'' spring lift.
- JimnyX19
07 Aug 2012 14:47 #45631
by JimnyX19
Replied by JimnyX19 on topic Re: Body lift
I just looked on jimny bits now and thu say recommended for 3" lift and above or 31" tyres +..... Has anyone also done 2" body lift and 3" susp lift without buying a dropped pitman arm and had any problems without one? Cheers for info smoggy
- Paul4x4
07 Aug 2012 15:01 #45632
by Paul4x4
Replied by Paul4x4 on topic Re: Body lift
Bodylift doesn't affect steering geometry in any way, so there's no need for dropped pitman arm on just 3" suspension lift. People just seem to have some weird urge to bolt every aftermarket part onto their trucks without even knowing what they are meant for... :whistle:
But I would recommend getting just the 2" suspension lift kit, because 2+2" lift would be more than enough for tires up to the sizes that stock axles can't handle anymore, and the truck would drive better than on 3" lift...
- JimnyX19
07 Aug 2012 15:19 #45633
by JimnyX19
Ok cheers paul haven't got the lift kit yet only the parts above but still not 100% what kit to go for , I thought about 3" size as I thought in the future if I wanted 16" wheel instead it would be fine as I would have 2 " body lift + 3" lift
- markyp2000
07 Aug 2012 16:48 #45638
by markyp2000
Replied by markyp2000 on topic Re: Body lift
i have a 4.5" lift and i havnt fitted a pitman arm i have had no troubles what so ever
as for the transfer box leaver take it out cut it about 1" up from where it goes in the box and weld in a 2" bit of metal
Time to create page: 0.094 seconds
