Crankshaft sensor
  • Adamski
16 years 2 months ago #4548 by Adamski
Replied by Adamski on topic Re:Crankshaft sensor
facade wrote:
I got them backwards :blush:
You likely have both sensors, you need to find out which one to change. If the engine stops altogether, likely it is the cam sensor.
If the crank sensor goes the engine light comes on and it runs in limp home mode.
You can buy an OBD2 fault code reader from eBay for about £20 that will work on a 2002, allow you to find which sensor is faulty and clear the error code.
The reader will work on most petrol cars from 2003, but the Jimny complied with OBD2 in 2000 (Japanese built).
There are cam sensors on eBay for about £35.
ahh in that case I do think it is the Crankshaft sensor which has gone. is that the sensor at the front of the engine? my symptoms are when it gets hot (after being stuck in a traffic jam) the rev needle started to bounce all over and the engine management light flashes on and off killing the power. if I turn it off and straight on it still happens, if I let it cool for 5 minutes the car runs fine again.
16 years 2 months ago #4549 by mlines
Replied by mlines on topic Re:Crankshaft sensor
It has been widely suggested that if you carry some water with you then when it happens again pour water on each sensor in turn. When the car starts to run fine again then you have found the faulty sensor.
  • Nelson83
16 years 2 months ago #4558 by Nelson83
Replied by Nelson83 on topic Re:Crankshaft sensor
I had the sensors go on mine last year - its a 52 plate special the same as your Adamski (but in black). I changed both sensors and it cost just over a £100 quid for both from the main dealer. I thought it best to do both in one hit.
The one at the front of the engine is easy to get to, but the one near the alternator was a bit of a pig. I used a large breaker bar to lever the alternator sideways after id slackened the bolts and then used 3 extension bars (foot long) on the end of the rachet to undo the nut. Took a little over 1 hour to do both with minimal tools.
  • ooky_123
16 years 2 months ago #4559 by ooky_123
Replied by ooky_123 on topic Re:Crankshaft sensor
same here ...
  • Adamski
16 years 2 months ago #4589 by Adamski
I think I've identified the faulty sensor to be the camshaft sensor using the old water technique to cool the sensors till the problem goes away. I've ordered a new sensor from Suzuki at a cost of £62 and it will arrive on Tuesday. Fingers crossed that this fixes the problem!
  • Adamski
16 years 1 month ago #4911 by Adamski
And so it continues :( ....
I have replaced the Camshaft Sensor and still have exactly the same problem. Does this point towards the Crankshaft Sensor being faulty? or could I have bought a knackered camshaft sensor from the dealer (a long shot I know but just want to be certain). Im getting sick of this problem so if a new Crankshaft Sensor is required I will just fit one, then both sensors have been changed and will have to hope for the best.
Any thoughts would be greatly appreciated :).
Adam
Time to create page: 0.104 seconds
