Crankshaft sensor
  • ooky_123
24 Oct 2012 12:28 #51165 by ooky_123
Replied by ooky_123 on topic Crankshaft sensor
Just quickly, is yours a soft top or hard top ?
When you look at your engine does it have a black plastic cover ontop of the engine or is it alloy ?
  • adam
24 Oct 2012 13:06 #51166 by adam
Replied by adam on topic Crankshaft sensor
Its a hard top and I think its a metal cover :S
  • ooky_123
24 Oct 2012 13:24 #51167 by ooky_123
adam wrote: Its a hard top and I think its a metal cover :S
Ok, so its most probably the G13BB engine ( the older engines, same as the SJ's ).
I believe the sensor is at the front of the sump... the oil pump is tapped to accept it. There should be an exploded "under bonnet" view in Martin's How to section ... Failing that, try searching the archive for "G13BB Crank Sensor" ... Ill have a trawl too, see if I can find anything
  • adam
29 Oct 2012 17:00 #51570 by adam
Hi Ooky_123, Iv tried looking under my bonnet but still cant find it.
There is an engine management garage in town I might take it to for them to have a look.. Thanks for your help. At least I kind of know what to say to them now! :blink: :whistle:
  • jonesyba420
03 May 2013 22:26 #69949 by jonesyba420
Replied by jonesyba420 on topic Crankshaft sensor
I have this same issue but seem to get conflicting information, is the crankshaft sensor the one at the front of the engine or the one under the alternator? i have a 2002 jimny the DOHC one with both the camshaft and crankshaft sensors. i believe from reading other people issues that i need the crankshaft sensor.
  • Damohick
03 May 2013 23:09 #69953 by Damohick
Replied by Damohick on topic Crankshaft sensor
When I had the same problem as you it was the one behind the alternator. It sound silly but take it out and get it hot so it starts playing up and then squirt a little water on the sensor to cool it down. If the car starts running properly again then you'll know that it's at fault.
Time to create page: 0.219 seconds
