Jimny EGR valve
  • Dave c
19 Jul 2012 23:00 #44571 by Dave c
Jimny EGR valve was created by Dave c
Has anyone had any problems with there EGR valve on there single cam 16v jimny ???
Not sure if they ever give any trouble ??
Also as the name suggests EGR being Exhaust Gas Recirculation.how does it connect to the Exhaust side of the engine when its bolted to the inlet manifold side or am i missing somthing :huh:
  • 247sniper
20 Jul 2012 06:40 #44577 by 247sniper
Replied by 247sniper on topic Re: Jimny EGR valve
Hi mate,
The exhaust gases are passed back through a approx 10-12 mm metal pipe from the exhaust maniforld back to inlet manifold.
They can give trouble on any car.
Are you having problems with the running of your vehicle or something?
Steve.
  • wanderinstar
20 Jul 2012 07:17 #44580 by wanderinstar
Replied by wanderinstar on topic Re: Jimny EGR valve
I have had problems on 2 occasions with these valves. What I cant get my head around is this.We fit air cleaners to keep the inlet air clean. Then we pump dirty oily exhaust gas back into the engine. Where is the logic.
20 Jul 2012 07:30 #44581 by robs5230
Replied by robs5230 on topic Re: Jimny EGR valve
its done to keep emissions down. not applicable on a diesel , only visible smoke so that's why many disconnect them on diesel motors.
standard jimny - for now
  • markyp2000
20 Jul 2012 09:10 #44584 by markyp2000
Replied by markyp2000 on topic Re: Jimny EGR valve
EGR helps warm the engine up quicker to get it to run at it most afishancy in emisions and is the egr on a jimny passed back through the head not a pipe correct me if im wrong
  • Dave c
20 Jul 2012 10:31 #44589 by Dave c
Replied by Dave c on topic Re: Jimny EGR valve
that does sound right as i cant see a pipe back to the exhaust manifold so must come through the head just seems to be bolted to the inlet manifold with a steel pipe up to the plenum generally EGR valves ive seen in the past are bolted to the exhaust manifold themselves with a pipe feeding into the plenum.
Time to create page: 0.208 seconds
