Jimny EGR valve
- markyp2000
20 Jul 2012 13:40 #44598
by markyp2000
Replied by markyp2000 on topic Re: Jimny EGR valve
if you think its giving troble blank it off and and see how it goes
20 Jul 2012 17:04 #44601
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re: Jimny EGR valve
I've a spare manifold complete if you are interested?
Grey pick up Jimny
20 Jul 2012 17:15 #44602
by facade
That should light up the eml. The ecu usually pulses the valve and looks for a change in rpm.
On a petrol engine the egr valve when working increases engine efficiency at part load, and keeps exhaust gas temperatures down, so the valves last longer.
It is disabled at full load.
Diesels are a different story...
Replied by facade on topic Re: Jimny EGR valve
markyp2000 wrote: if you think its giving trouble blank it off and and see how it goes
- markyp2000
20 Jul 2012 18:35 #44607
by markyp2000
i said blank it off and see how it goes only for diagnostics resons not leave it blanked off if it better ether clean the egr or replace it or leave it alone and live with it but rereading the first post have you got a problem or are you just asking if thay give problems
- Dave c
20 Jul 2012 23:12 #44636
by Dave c
Replied by Dave c on topic Re: Jimny EGR valve
Yes i do have a problem engine starts fine runs good until it warms up then starts to idle rough as hell
Cant really get to the bottom of the problem its a 1.6 motor with jim jam inlet ecu and fitted wih the green/blue baleno injectors.
If i introduce a very small amount of air into the manifold by just cracking 1 of the vac hoses it smooths out and runs good and as the EGR pipe runs into the manifold as wondering when does it feed the gases back in and could it be the valve is not opening or there is maybe a blockage,
EGR just seems to be one of them thing you have to live with but is hard to grasp what effect it has
- markyp2000
21 Jul 2012 11:37 #44665
by markyp2000
could be a coolent temp sensor when it warm the ecu may think its still cold and is putting to much fuel in and when you crack the pipe off you put more air in which is going to weeken the mixchure down may be
Time to create page: 0.408 seconds
