Jimny EGR valve
  • Dizzy37
17 Apr 2018 17:07 - 17 Apr 2018 17:09 #191821 by Dizzy37
Replied by Dizzy37 on topic Jimny EGR valve
Oops sorry Mick thought this was better as it was the same subject.
It's an '03 1.3 petrol Jimny soft top JLX O2. I've found out it's just to the right of the battery to the rear of the engine bay. I've been kindly given a service manual so going to attempt at the weekend.. Do you know if you have to spray/lubricate before you refit as manual doesn't mention
Last edit: 17 Apr 2018 17:09 by Dizzy37.
  • mickt
17 Apr 2018 17:41 #191827 by mickt
Replied by mickt on topic Jimny EGR valve
A lot of members see the start date and don't bother reading what can be a long drawn out saga is why it is best to start a new one. You can always mention the fact that you have read the history. Anyway the reason I was asking is I was using my disc to check where they are . But you seem to be on top of it so best of luck. I don't think there is anything to lubricate. Nice and clean and dry is what it needs.
  • Kabani
05 Dec 2018 02:54 - 05 Dec 2018 02:55 #198658 by Kabani
Replied by Kabani on topic Jimny EGR valve
I have the M13a engine, non vvt.
A hundred km ago I decided to blank the egr. Easy Custom job. Done with house tools. The hardest is to bolt and unbolt the line behind the engine that goes to the throttle body.
I still haven't got the checkengine light. Throttle response improved, I might say there's a noticeable performance gain in low range rpm. I'd like to believe an engine this small will not deliver bad emission results but I'll tell that later in a month when I take my jimny to emission tests.
Regarding Fuel economy I perceive also improvement. Usually the fuel needle is a bit down from where it is right now, given the distance driven.
I'll update more results in a month.
Last edit: 05 Dec 2018 02:55 by Kabani.
09 Dec 2018 20:42 #198816 by Rhinoman
Replied by Rhinoman on topic Jimny EGR valve
EGR boosts low and mid range performance and economy by part filling the cylinder with spent gasses - that improves the effective compression ratio and also reduces pumping losses. It has no effect on peak power because its not active under heavy loads. If you are seeing an improvement then you must have had a fault.
  • Kabani
18 Dec 2018 19:30 #199165 by Kabani
I also believe it has a fault. Maybe it is unable to fully close.. I'm gonna clean it..and the throttle body as well.
I cleaned the throttle body almost two years ago. Back then I didnt know about the existence of the egr. I didn't understand why the throttle body was so dirty.
After the first fuel fill up I got better city mileage. Im gonna keep the egr blanked until i'm ready for cleaning the whole thing.
Time to create page: 1.798 seconds
