Diff oil leaking from my swivel's??????
- Jamie
05 Aug 2010 14:21 #4069
by Jamie
Replied by Jamie on topic Re:Diff oil leaking from my swivel's??????
Wheelbearing replaced today and it looks to be leaking still!!!!
I think I'm gonna have to strip it down on Saturday arrrgggghhhhhh
05 Aug 2010 18:49 #4079
by kirkynut
Replied by kirkynut on topic Re:Diff oil leaking from my swivel's??????
Did you replace the oil seal again? It's that that is leaking, the bearings being worn either now or before can be the cause of the seal leaking but you must replace the seal. As I have said, i replace mine every time I take the hub apart, they are cheap enough to do so, therefore I do.
- Jamie
06 Aug 2010 11:40 #4105
by Jamie
Yes I did the oil seal when I replaced the kingpins last week...
Oil leaks normally come from the shaft moving around in the seal, not the seal itself which is why it is normally the knigpins or wheelbearing!!!!
06 Aug 2010 14:01 #4109
by kirkynut
The shaft is allowed to move by the play in the bearing and moves in the seal causing it to leak but if you'be replaced the seal and bearings I'm at a loss too, unless as others have suggested you have a blocked breather?
Sorry, I'm out of ideas.
- Jamie
06 Aug 2010 16:12 #4111
by Jamie
I know!!! It's a tricky one this, I'm gonna pull
It to bits tomorrow, check it's not a "dodgy" seal
and perhaps put another new one in!!!
My breathers are ok first thing I checked, after
that I'm at a loss, it could be oil left in there before
that is still weeping out.....
Next inspection tomorrow!!!!
14 Aug 2010 13:36 #4223
by kirkynut
How did you get on Jamie? Have you stopped it leaking?
Time to create page: 0.224 seconds
