Diff oil leaking from my swivel's??????
- Jamie
02 Aug 2010 16:52 #4029
by Jamie
Diff oil leaking from my swivel's?????? was created by Jamie
I am leaking diff oil from my swivel's but i only did my kingpin's
on the same side around 2 weeks ago. The oil is coming out nice and clean
not like the usual gunk around there.
I have checked my wheel bearing and there is zero play in them, i remember when i did my kingpins i cleaned up my cv joint and there
was a few rust spots on there and a very slight stiffness in the joint.
Also there is a slight "floating" feeling on the steering at about
55mph on the motorway, but i put this down to the Special Track's.
Any ideas anyone??
Thanks
Jamie
Any ideas anyone??
Thanks
Jamie
02 Aug 2010 17:33 #4030
Replied by mlines on topic Re:Diff oil leaking from my swivel's??????
Pressure build up (blocked breather)?
Bent halfshaft?
Bent axle case?
Incorrectly seated/split/worn oil seal?
Bent halfshaft?
Bent axle case?
- Jamie
03 Aug 2010 05:31 #4032
by Jamie
Replied by Jamie on topic Re:Diff oil leaking from my swivel's??????
I don't think it's shaft or axle related as I've not had tin 4x4 since I did
The kingpins, and it was leaking before I did the kingpins as that's what I thought it was!!!!
Everything tells me it's the wheel bearing but there doesn't seem to be anything wrong with it!!
If the wheelbearing was gone would the half shaft be moving???? I just can't find any play in there!!!
Jamie
Jamie
03 Aug 2010 10:13 #4038
by kirkynut
Replied by kirkynut on topic Re:Diff oil leaking from my swivel's??????
As Martin says. Did you replace the oil seal and was it in right?
Were you rough with it when putting the half shaft back in?
You can't tell if they're worn by sight always so for the couple of quid they cost replace every time you take it apart or you have to do it all over again like now.
Did your king pins go in properly?
If one is slightly not knocked in properly it will have the same effect as a knackered bearing.
- Jamie
03 Aug 2010 13:56 #4045
by Jamie
I put it all together right when I did it last time, but it was doing this before that's why I
Replaced the kingpins as I thought they had worn again!!
It's defiantly not an axle problem as it leaks in2wd and nothing at the front is turning apart from the wheelbearing, but the bearing has zero play in it, the cv joint however did feel very slightly stiff but I gave it a good clean and lube. I'm gonna pull it apart at the weekend see if there is anything obvious!!
- andyw
04 Aug 2010 07:46 #4055
by andyw
Replied by andyw on topic Re:Diff oil leaking from my swivel's??????
Hi, Well the only place your going to get oil is your diff, so sounds like the little oil seal/s.
Have you been on any side slopes type terrain, also is it just one side it's coming from?
It's just a shame it's a big job just to do the seals at least there cheap
Andy
Andy
