Engine died and will not restart??? *** Fixed! ***
- ZookFastback
vitara_mad wrote: the imobilizer works on a chip in the key all jimnys have them when you turn ignition on the eml will flash if there is a fault with the imobilizer loosing its code
Nah mate, not all of them had immobilisers and not all had them in the keys. Earlier Jimny's had keyring remote for immobiliser/keyless entry.
- vitara_mad
never seen 1 in the uk all vits , gv's & jimnys from 97 on had the imobilizer chips in the key
If the immobiliser light is on then it could be a dislodged or broken pickup coil behind the ignition key, this is quite a common fault.
- freeduc
I borrowed an Innovate Motorsports LM2 that can read all kinds of odbII values. However, it seems it struggles with the Jimny. Anyone else having problems reading from the odbII connector? Found some posts about that but I thought it was with older cars, mine is a 1998. I'll move on with that pin-trick that was proposed.
Immobilizer - I have no immobilizer light and no mensioning of an immobiliser in the manual.
Will keep you posted, really really annoying this...
//Fredrik
- reaper
You can get obd1 readers but they are expencive and only offer limited diagnostic
- freeduc
Good answer...
//F
