Engine died and will not restart??? *** Fixed! ***
05 May 2012 16:40 #39369 by facade
The usual cause of sudden stopping is cambelt failure, but it shouldn't fire at all :huh:
Check the cam is actually going round first of all, they tend to shear all the teeth off around the crank, and look perfect.
Then look for a spark, then check the fuel pressure.
  • freeduc
20 May 2012 12:30 #40762 by freeduc
Replied by freeduc on topic Re: Engine died and will not restart???
Ok, the mystery deepens:
* Cambelt? Camshaft turns fine + belt have good tension
* Fuel? A very nice spray when disconnecting the fuel rail. Repeatedly.
* Spark? Yes.
* The immobilizer lead (even though I don't have an imobilizer light)... From the workshop manual:
"When a trouble exists in the immobilizer control system (when immobilizer control module or ECM detects a diagnostic trouble code (DTC)), ECM will stop operation of the injector and ignition of spark plug." But I did see sparks...
As before the car turns over fine when running the starter but absolutely refuses to start. And it died when driving along at 50km/h without any load at all. And no mechanical noises of any kind.
Any more ideas out there?
Regards,
//Fredrik
20 May 2012 15:00 #40779 by j999pre
Have you tried a different cam sensor?
Have you had the rocker cover off to check that the cam is in one piece and not snapped? Although you would hear it.
Any split hoses allowing air in anywhere?
Both coil packs ok?
Has it jumped a tooth on the timimg? Has the timing been checked?
Just a few things to start with.
Grey pick up Jimny
  • rjd1
20 May 2012 17:06 #40797 by rjd1
Replied by rjd1 on topic Re: Engine died and will not restart???
for engine to run simplify everything
fuel you say you have
spark you say you have
next can it breath unclip top of air box see if she will fire had similar yrs ago with 1 st jimny bit o rag got sooked into intake
check the basics bud then the other stuff
  • freeduc
15 Jun 2012 18:49 #42428 by freeduc
Lo and behold! A week ago, I discontected the lambda after everything else failed to show any errors. The car actually started and ran very, very weekly. Could no be driven as it would die immediately. I ordered a new lambda and put it in today - and it runs!!! Fantastic! This has been the strangest error ever as the lambda actually broke down while driving, making it very hard to understand what was wrong, also the blinking-suzuki-error-msg gave the impression everything was ok.
Very happy with a beer in my hand!
//F
Time to create page: 0.139 seconds
