why does my engine cut out?
- mike from manchester
25 Mar 2012 09:01 #36317
by mike from manchester
Replied by mike from manchester on topic Re: why does my engine cut out?
Hi All, Thanks very much for your suggestions,it could be any of the above, all seem to have similar features.Suppose I will start working my way thru them all.
kind regards
Mike.
kind regards
Mike.
- Dutchjimny
11 Apr 2012 19:15 #37338
by Dutchjimny
Replied by Dutchjimny on topic Re: why does my engine cut out?
Can i have a part number and maybe a drawing from the garage manual or a pic? today mine had it 4times and the last time i was stuck in some serious mud so needs to be replaced asap!
- Dutchjimny
16 Apr 2012 15:19 #37744
by Dutchjimny
please?
16 Apr 2012 15:40 #37745
by j999pre
Which engine do you have? M13aor G13BB and soft top or manual?
Grey pick up Jimny
Replied by j999pre on topic Re: why does my engine cut out?
Dutchjimny wrote: please?
Grey pick up Jimny
17 Apr 2012 07:59 #37813
by Obarno
Replied by Obarno on topic Re: why does my engine cut out?
For an M13a engine I can give you Intermotor part numbers
Crank sensor 19151
Cam sensor 19157
Sorry can't give you genuine Suzuki part numbers as I didn't buy them!
However the crank sensor has a number on it J5T23891 M and 1519
and the cam sensor just has the number 111006 on it
They both look identical to the original part. I also suspect that Suzuki would have them made for them rather than make them themselves.
Crank sensor 19151
Cam sensor 19157
- Dutchjimny
17 Apr 2012 18:53 #37857
by Dutchjimny
im sorry my bad! its an G13BB 2000 hardtop model on normal fuel
Time to create page: 0.096 seconds
