why does my engine cut out?
18 Apr 2012 19:34 #37935 by j999pre
You only have a Cam sensor then. Its on the back of the cam cover at the top of the engine. An electrical plug and an earth lead should be on it. Its held in with a 10mm bolt.
Grey pick up Jimny
  • Dutchjimny
18 Apr 2012 20:07 #37955 by Dutchjimny
Replied by Dutchjimny on topic Re: why does my engine cut out?
Can i test it with a meter? how many resistance should it have?
18 Apr 2012 21:26 #37968 by j999pre
Next time it cuts out cool it with some water. If it starts then you know its that.
Other thing to consider is a blocked breather or petrol cap. When it cuts out remove the cap, if there is a big vacuum this could be the problem.
Best of luck.
Grey pick up Jimny
  • ZookFastback
18 Apr 2012 21:50 #37971 by ZookFastback
Replied by ZookFastback on topic Re: why does my engine cut out?
This is link to the cam angle sensor for G13BB engine, on Ebay. Very cheap and easy to replace.
www.ebay.com.au/itm/Cam-Angle-Sensor-Suz...20d4dfe#ht_804wt_828
Time to create page: 0.091 seconds
