why does my engine cut out?
  • mike from manchester
22 Mar 2012 16:16 #36193 by mike from manchester
why does my engine cut out? was created by mike from manchester
Hello, I have a 2000 w reg jimny which sometimes cuts out in traffic,the engine temp is normal.The engine runs lumpy for a few seconds then cuts out .it will not restart until at least 10 minutes.if i put my foot on the accelerator to give it more gas it has no effect apart from the rev counter needle ' bounces ' shortly before cutting out.Last year i put it in a garage and they had it running all day no problem,also diagnostic check showed all ok.it seems to cut out either on approach to a roundabout or at a junction making everybody else angry. my wife is fed up as it always happens to her. Anyone got any ideas what could be the cause.
Thankyou
ps its not my wifes driving!!
  • darthloachie
22 Mar 2012 16:25 #36194 by darthloachie
Replied by darthloachie on topic Re: why does my engine cut out?
Hi Mike
have a look on this thread see if it helps
www.bigjimny.com/index.php?option=com_ku...7&id=34678&Itemid=75
if not I'm sure one of the engine experts will be along soon to help :)
  • adamjimny
22 Mar 2012 19:37 #36201 by adamjimny
Replied by adamjimny on topic Re: why does my engine cut out?
sounds very much like the cam angle sensor problem if its a g13bb engine
  • Dutchjimny
22 Mar 2012 19:44 #36202 by Dutchjimny
Replied by Dutchjimny on topic Re: why does my engine cut out?
i had the same problem once it was a bit warmer outside.. but it never happened again..
  • ZookFastback
23 Mar 2012 05:16 #36209 by ZookFastback
Replied by ZookFastback on topic Re: why does my engine cut out?
My prob was the same and it was the cam angle sensor. Cheap to replace and prob immediately solved.
The device is at the back of the G13BB motor, just behind the rocker cover at the firewall end. Couple of wires leading out of it.
23 Mar 2012 08:15 #36212 by Obarno
If its a M13a engine it could be the crankshaft sensor. It is located behind the alternator, and because of its position gets very hot. Your symptoms are typical of cam and crankshaft sensor faults. For some reason they don't always show as a fault if you plug in an OBD reader.
Time to create page: 0.162 seconds
