front axle binding
- adamjimny
14 years 8 months ago #35293
by adamjimny
Replied by adamjimny on topic Re: front axle binding
no worries ill check them again :pinch:
14 years 8 months ago #35321
by facade
Replied by facade on topic Re: front axle binding
Make sure the hubs are free, and nothing inside the axle can bind, as nothing goes round in 2wd. The MOT doesn't use 4wd so you don't need fix it before.
If it is still binding and the hubs are free and it is in 2wd you have a big problem.
- adamjimny
14 years 8 months ago #35355
by adamjimny
i know this but i have locked hubs so it all turns even when in 2wd all rotates smoothly then just binds.....really weird
facade wrote: Make sure the hubs are free, and nothing inside the axle can bind, as nothing goes round in 2wd. The MOT doesn't use 4wd so you don't need fix it before.
- adamjimny
14 years 8 months ago #35563
by adamjimny
Checked and both cv's are like new and had a detailed feel and its something not 100% in the diff soo what could cause this problem in the diff?
Sent from my GT-I9100 using Tapatalk
- supergaz
14 years 8 months ago #35575
by supergaz
Replied by supergaz on topic Re: front axle binding
Failed bearing in the diff? Sounds like you will need to pull it out.
- adamjimny
14 years 8 months ago #35576
by adamjimny
Yeah im thinking that or debris gettin trapped in ring n pinion.....hoping for the latter
Time to create page: 0.095 seconds
