front axle binding
  • adamjimny
11 Mar 2012 16:18 - 11 Mar 2012 16:20 #35281 by adamjimny
front axle binding was created by adamjimny
iv got a problem with the front axle that it locks up and stops forward movement but its okay in reverse.
iv narrowed it down to
  1. drive shaft broken
  2. diff busted
  3. crown and pinion got some debris in teeth
does anybody know whats happening or had any similar problems as i want it fixed asap then i can get an MOT booked
Last edit: 11 Mar 2012 16:20 by adamjimny.
  • Paul4x4
11 Mar 2012 16:41 #35284 by Paul4x4
Replied by Paul4x4 on topic Re: front axle binding
Sounds like a busted CV joint to me.
  • adamjimny
11 Mar 2012 16:53 #35285 by adamjimny
Replied by adamjimny on topic Re: front axle binding
its not when turning
i can move 5 meters or so then it just locks
if it was a cv surely it would be constant and when under pressure?
  • Paul4x4
11 Mar 2012 16:55 #35286 by Paul4x4
It still sounds like a cv to me.:laugh:
  • adamjimny
11 Mar 2012 16:59 #35288 by adamjimny
how can you tell if they have gone as they seemed fine when i had them out or can they be knackered and still seem fine?
  • Paul4x4
11 Mar 2012 17:11 #35291 by Paul4x4
adamjimny wrote: how can you tell if they have gone as they seemed fine when i had them out or can they be knackered and still seem fine?
The one that would be causing the problem you're having, would more likely have seemed to be in pieces than fine.:laugh:
If you have inspected them after the binding occurred, and they looked fine, then they sure aren't causing that.
Once my wheel bearings went on one side of my SJ's front axle, and that caused similar problems. But I don't think broken shafts or diff could cause that...
