front axle binding
  • wanderinstar
14 years 8 months ago #35599 by wanderinstar
Replied by wanderinstar on topic Re: front axle binding
If the crown wheel has lost a tooth. Could it be picked up while going forward but not while in reverse??
Just an idea.
  • adamjimny
14 years 8 months ago #35611 by adamjimny
Replied by adamjimny on topic Re: front axle binding
Thats what i was thinking.
Gonna flush it and hopefully find a broken tooth and run with it untill it fails completely
Sent from my GT-I9100 using Tapatalk
  • wanderinstar
14 years 8 months ago #35620 by wanderinstar
You may want to try one of those magnetic pick ups through the drain hole.
  • adamjimny
14 years 7 months ago #36062 by adamjimny
Well had chance to look at it today when i woke up so i fitted rear prop on with its new uj so tranny box is fully mounted now and works bob on.
Diff wise i drained oil and found a few small bits but nothing serious so then stuck a magnetic pen in drain hole a dozen times and found this and luckily thats all.
Attachment uploadfromtaptalk1332273614811.jpg not found
So jobs left to do
1. fill diff up with oil
2. Clean rear brake adjusters
3. Mount and wire up winch
4. MOT
So 3 non messy jobs but all reasonably simple once iv ordered oil for diff. Just not sure if wires on winch are long enough so need some longer ones with anderson connector to dissconnect when not in use.
  • wanderinstar
14 years 7 months ago #36066 by wanderinstar
Another thing i would be tempted to do woudd be to get a high pressure spray and spray paraffin in through filler hole and catch anything that came out. The oil may act a bit like glue and hold any other loose debris in there.
  • supergaz
14 years 7 months ago #36068 by supergaz
Replied by supergaz on topic Re: front axle binding
Or maybe through the breather.
Time to create page: 0.087 seconds
