Fitting tyres DIY
- SOTA
21 Jan 2012 20:39 #31509
by SOTA
Fitting tyres DIY was created by SOTA
Does anyone fit their own tyres?
My local kwikfit won't fit my old tyres onto my replacement rims, can't take the risk they say.
They will balance them, so I thought I might give tyre fitting a go.
Do I need a bead breaker or will jumping on them work?
I can get tyre levers, if I can get tyres off and on with just them that is.
- myers647
21 Jan 2012 20:41 #31511
by myers647
Replied by myers647 on topic Re: Fitting tyres DIY
yes mate you should be ale to do it yourself. Use a sledge hammer & a metal wedge to hit the Tyre wall to brake the bead.
- supergaz
21 Jan 2012 20:52 #31512
by supergaz
Replied by supergaz on topic Re: Fitting tyres DIY
To be honest its better to go to another tyre place, preferably not NOT so Kwick Fit / ATS or Halfrauds auto centres.
I know there are plenty local to you. Its not worth working up a sweat fitting tyres yourself.
- myers647
21 Jan 2012 20:59 #31514
by myers647
i agree to be honest it will only cost a few quid. go to a small garage none of the big named ones and i am sure they will sort you out.
- zuki andy
21 Jan 2012 21:34 #31520
by zuki andy
Replied by zuki andy on topic Re: Fitting tyres DIY
yes fitting tyres at home with tyre levers is quite easy, trying to get the old tyres off the bead very hard, i did it by driving a terrano onto it (a little jimny just aint heavy enough) take them to a independent /small tyre fitting company and save yourself from alot of sweating and swearing :silly:
it should cost about £40 fitted and balanced
- grumpy22
21 Jan 2012 22:14 #31523
by grumpy22
Replied by grumpy22 on topic Re: Fitting tyres DIY
I've done it at home. Made a bead breaker years ago using a trolley jack.
But.....
It's proper had work even after the bead is broken.. Find a local indie they'll do it for you for a few ££ more than balancing alone. Never again!
But.....
Time to create page: 0.164 seconds
