Fitting tyres DIY
  • trextr7monkey
22 Jan 2012 15:38 #31546 by trextr7monkey
Replied by trextr7monkey on topic Re: Fitting tyres DIY
Our local scrappy fits tyres and balances them at very competitive rates if we buya set of wheels and want tyres knocking off sometimes they dont charge so long as you take all of the tyres away - it costs them to dispose of the old omes.
Apart from tralier and barrow tyres I wouldn't attempt to swap tyres at home - have done it in the past with vices, clamps, bits of rope etc but a total pia compared to watching someone do it effortlessly with the correct gear :D
atb
Mike
  • SOTA
22 Jan 2012 17:30 #31558 by SOTA
Replied by SOTA on topic Re: Fitting tyres DIY
Thanks folks, good advice, I'll keep looking for a friendly fitter.
  • mcjimny
22 Jan 2012 17:47 #31564 by mcjimny
Replied by mcjimny on topic Re: Fitting tyres DIY
If you have no joy with local independents if you know anyone thats into bangers or stocks a lot of those boys have the gear and will do it for beer money.
  • teafortwo0789
22 Jan 2012 18:12 #31569 by teafortwo0789
Replied by teafortwo0789 on topic Re: Fitting tyres DIY
It should be possible to make a DIY system for emergency use. VW have a drawing for workshops to make their own in the 1950's / 60's.
It may be possible to use the rear wheel hanger to hold the wheel steady with a central rod at right angles to the wheel attached to the wheel holder. It should be possible to attach a bar to this central rod hinged at the end and a curved piece attached to the lever to coincide with bead.
Not a good description so I'll see if I can dig out the original VW drawing which will at least show the concept.
  • Nobby22
22 Jan 2012 18:15 #31570 by Nobby22
Replied by Nobby22 on topic Re: Fitting tyres DIY
I used a local independent tyre fitter, mainly because all the big names wanted over a £100 per tyre :ohmy: . I suspect most will be willing, a jobs a job in this economic climate. I have a friend who says its easy to fit tyres by hand but then he has done it loads. P.s. a sliding bead breacker makes cracking the bead a peice of p***. The next bit tends to be a bit harder though :laugh: .
Nobby
22 Jan 2012 18:51 #31576 by mlines
Replied by mlines on topic Re: Fitting tyres DIY
I tried the "take the wheel off and jack up the car on top of the wheel bead using a hi-lift jack " method......followed by a hi-speed dash to hospital casualty.
Time to create page: 0.090 seconds
