JIMNY BATTERY
  • SUGAR DELTA
16 Jan 2012 17:05 #31081 by SUGAR DELTA
JIMNY BATTERY was created by SUGAR DELTA
Hi folks.
I don't own a jimny yet but had a look around one last week.
I didn't realise the battery is so tiny on them!
Can anyone tell me what amp the standard battery is and is it possible to put a higher ampage battery on them as I want to run high power radio equipment in mine when I buy it.
Cheers folks B)
16 Jan 2012 17:22 #31082 by facade
Replied by facade on topic Re: JIMNY BATTERY
The standard fit is a type 157 (B33)
45AH 330CCA with small Japanese terminals
You can get a physically bigger battery in the space (with more capacity), if you can't get a small terminal version you will need to fit standard terminal clamps.
  • SUGAR DELTA
16 Jan 2012 17:47 #31086 by SUGAR DELTA
Replied by SUGAR DELTA on topic Re: JIMNY BATTERY
Cheers for the reply,all I need is around 60 amps.
I will see if they do a larger capacity type 157,because it sounds a pain changing to fit standard terminal clamps. :(
  • SUGAR DELTA
16 Jan 2012 17:51 #31087 by SUGAR DELTA
Seems 45 is the limit for these slim batteries.
I would be interested to know if anyone else on the forum has put a higher ampage battery in that small gap :)
  • reaper
16 Jan 2012 17:54 #31088 by reaper
Replied by reaper on topic Re: JIMNY BATTERY
for high powerd audio a second battery and split charge system would be a better way to go
  • darthloachie
16 Jan 2012 20:15 - 16 Jan 2012 20:16 #31113 by darthloachie
Replied by darthloachie on topic Re: JIMNY BATTERY
have a look at an optima yellow top
expensive but you get a deep cycle battery for running amps together with a cca of 460a for starting and will fit in the standard jimny location
www.tayna.co.uk/Optima-Yellow-Top-YT-S-2.7J-P3803.html
Last edit: 16 Jan 2012 20:16 by darthloachie.
Time to create page: 0.176 seconds
