JIMNY BATTERY
  • SUGAR DELTA
16 Jan 2012 20:30 #31118 by SUGAR DELTA
Replied by SUGAR DELTA on topic Re: JIMNY BATTERY
darthloachie wrote: have a look at an optima yellow top
expensive but you get a deep cycle battery for running amps together with a cca of 460a for starting and will fit in the standard jimny location
www.tayna.co.uk/Optima-Yellow-Top-YT-S-2.7J-P3803.html
Thanks for info,my gear needs around 60 amps in all to use and that is only 38 :( so I guess that won't be enough?
Unless deep cycle gives you more?
Sorry for my lack of knowledge!
16 Jan 2012 23:40 #31139 by ooky_123
Replied by ooky_123 on topic Re: JIMNY BATTERY
Second battery and split charging is the usual route ... Optimax Leisure Batterys give upto 1000Amps (Cold Cranking) and will run deep cycles. Only place really to mount is in the boot (and its gonna cost a fortune to run high current battery cablesthere ... unless you want to fabricate a second battery box under the bonnet)
Former owner of Little "Ooky", who has now started a new life in Shetland
  • ZookFastback
17 Jan 2012 06:38 #31141 by ZookFastback
Replied by ZookFastback on topic Re: JIMNY BATTERY
No eBay APP ID and/or Cert ID defined in Kunena configurationThis mob do a 2nd battery holder that fits under the bonnet...
  • SUGAR DELTA
17 Jan 2012 12:03 #31158 by SUGAR DELTA
Brilliant cheers folks.
  • doncarlyon
17 Jan 2012 14:22 #31164 by doncarlyon
Replied by doncarlyon on topic Re: JIMNY BATTERY
Easy enough to change battery terminals!
  • SUGAR DELTA
17 Jan 2012 17:07 #31182 by SUGAR DELTA
doncarlyon wrote: Easy enough to change battery terminals!
For you maybe lol,i'm crap at stuff like that.
It looks real tight though ,are we sure there is room to squeeze a bigger battery in that gap with no other mods?
Time to create page: 0.925 seconds
