JIMNY BATTERY
  • darthloachie
17 Jan 2012 20:09 #31197 by darthloachie
Replied by darthloachie on topic Re: JIMNY BATTERY
have a look on here - a topic including mounting a second battery under the bonnet
www.bigjimny.com/index.php?option=com_ku...8101&Itemid=75#28139
  • SUGAR DELTA
20 Jan 2012 18:22 #31427 by SUGAR DELTA
Replied by SUGAR DELTA on topic Re: JIMNY BATTERY
I think i'm gonna get a split charge system and get a 110Ah leasure battery in the boot.
Question,would the standard alternator be good enough for this task ?
Thanks :unsure:
  • tyepj
06 Apr 2013 19:32 - 06 Apr 2013 19:37 #68038 by tyepj
Replied by tyepj on topic JIMNY BATTERY
Mine came with a standard Jap battery. It is rated 34Ah.
I replaced it with a bigger 634 size battery rated at 45Ah.
Had to replace the battery terminals to match the larger battery.
Last edit: 06 Apr 2013 19:37 by tyepj.
  • JerseyJimny
06 Apr 2013 20:38 #68048 by JerseyJimny
Replied by JerseyJimny on topic JIMNY BATTERY
My two pence....
I run this system which is simple and cheap...
I custom made the batt tray to suit my needs and just linked up the second batt with the original seams to work with the extra gear I run
The alternator seams to hold up but it puts a strain on the belt
  • suzuki jimny fella
10 Apr 2013 17:23 #68379 by suzuki jimny fella
Replied by suzuki jimny fella on topic JIMNY BATTERY
i put yellow top in mine nice batt to £120 new and drops in same spot CCA 630 sweet
10 Apr 2013 21:03 #68420 by kirkynut
Replied by kirkynut on topic JIMNY BATTERY
I run one of these in the boot:
www.tayna.co.uk/Numax-CXV-X-1000-Amp-P7632.html
It saves the space under the bonnet issue but atthe detriment of boot space - not that there is any boot space to start with!
