ecu....some help
  • Paul4x4
14 years 10 months ago #30931 by Paul4x4
Replied by Paul4x4 on topic Re: ecu....some help
Are you sure there's only one coolant temp sensor? In many cars there's one sensor for fan, and another sensor that sends temperature signal to ecu. I have hard time believing that the fan would be operated by the ecu...:dry:
But on the other hand, I've been mainly working with older cars and trucks, so there might be something in newer cars for me to learn.:whistle:
  • tasos
14 years 10 months ago #30939 by tasos
Replied by tasos on topic Re: ecu....some help
This is the only sensor " seekpart24.com/suzuki/jimny-fj-98/1-5-dd...t-temperature-100334 ".... i didn t found anything else.
  • 247sniper
14 years 10 months ago #30975 by 247sniper
Replied by 247sniper on topic Re: ecu....some help
Hi,
Have you had the gas checked in te air con system? There is a pressure switch inline, it monitors the a/c pressure. If there is no gas or low pressure detected the air con will not work.
Steve.
  • tasos
14 years 10 months ago #31071 by tasos
Steve it was the first thing i done....check the a/c pressure and it was fine.....also change the pressure-static switch with a new one in any case.
  • 247sniper
14 years 10 months ago - 14 years 10 months ago #31089 by 247sniper
How did you check the pressure ??
Have you checked feeds @ the compressor ??
Steve.
Last edit: 14 years 10 months ago by 247sniper.
  • Paul4x4
14 years 10 months ago #31098 by Paul4x4
I'm 100% sure this problem is caused by the non-functioning fan. The a/c system needs the fan in order to work, so when you get the fan working again, your a/c problem is solved.;)
Time to create page: 0.140 seconds
