ecu....some help
  • tasos
14 years 10 months ago #30753 by tasos
ecu....some help was created by tasos
Hi,
First of all english isn't my mother language so....sorry if i write something $^#^&%^*
My problem.... I have a Jimny 08 diesel....last summer i push the a/c buttom....it turns the green light on but nothing else happen.... i though " it might needs freon...i went to a car electrician...he measured the pressure it was ok....we check a valve (replace it with a new) nothing....
Another problem i found was that the fan doesn't start when the cars temperature was high....
we ckeck the fan from the reles and both scales were working when we activate it manually...
I also change the coolant sensor....
What else should i look??? Can the ecu make all this??
14 years 10 months ago #30830 by Obarno
Replied by Obarno on topic Re: ecu....some help
Hi and welcome
I had a similar problem with the a/c on my car. The light came on, same as yours but it wouldn't work. The problem was the switch. Unfortunately you can't buy the switch on its own, it comes as part of the dashboard complete with the 2 heater rotary controls. Eventually I bought and wired a 2nd. hand heated rear window swicth and wired it across the orignal switch.
The complete story is here
www.bigjimny.com/index.php?option=com_ku...7&id=17056&Itemid=75
As you will see the a/c is also controlled by the 4wd position, so if you are in 4wd it won't work.
  • tasos
14 years 10 months ago #30839 by tasos
Replied by tasos on topic Re: ecu....some help
Thank you Obamo
I forgot to say that i have also try with a working dashboard from another jimny.....the owner let me try his working dashboard.....no difference.
  • Paul4x4
14 years 10 months ago #30845 by Paul4x4
Replied by Paul4x4 on topic Re: ecu....some help
I can't really help with your problem, but at least I can tell you that a/c system works on it's own, and the ecu has nothing to do with it.:)
  • Paul4x4
14 years 10 months ago - 14 years 10 months ago #30848 by Paul4x4
Obarno wrote: As you will see the a/c is also controlled by the 4wd position, so if you are in 4wd it won't work.
That sounds weird. Why would they design it that way?:blink:
Well, I don't have a/c, but if I had one, I would wire it to work with 4wd also...:whistle:
Maybe there's something wrong in that area with tasos's Jimny, and the a/c system somehow thinks that 4wd is engaged, and prevents it from working?
Last edit: 14 years 10 months ago by Paul4x4.
  • tasos
14 years 10 months ago #30878 by tasos
1) From a small research i do, i found that when the a/c turns on the fan starts too. (the ddis have 1 fan only)
2)The main problem is that when the tempurature lift up to 89 degrees....the coolant sensor (which works) send a signal to ecu to start the fan.....thats not happening.
So the coolant system (fan) have a relation with the a/c system somehow
Time to create page: 0.196 seconds
