ecu....some help
  • toph
16 Jan 2012 21:49 #31135 by toph
Replied by toph on topic Re: ecu....some help
Paul4x4 wrote: I can't really help with your problem, but at least I can tell you that a/c system works on it's own, and the ecu has nothing to do with it.:)
are you sure? i remember when i was wiring in the facelift dash to mine i looked at the wiring diagram and there was one or two wires from the heater controls that went to the ecu.
  • Paul4x4
17 Jan 2012 13:00 - 17 Jan 2012 13:00 #31162 by Paul4x4
Replied by Paul4x4 on topic Re: ecu....some help
No, I wasn't sure :laugh:
But now I dug up some wiring diagrams, and it seems like you're right. There's one wire coming from the ecu, and that controls the fan relay and the compressor relay. But if the compressor is working, there is nothing wrong there, so the problem is still at the fan.
I think that the a/c is working, but because the fan doesn't work, condenser won't cool down the gas in the system back into liquid form. That's why there's no cooled air coming inside the car.
So, I still believe that when the fan problem is solved, everything works after that.
Last edit: 17 Jan 2012 13:00 by Paul4x4.
  • 247sniper
17 Jan 2012 13:51 #31163 by 247sniper
Replied by 247sniper on topic Re: ecu....some help
It sounds like there is two problems here , fan is one and if the air in the car is not that cool then most likely it is your reciver dryer that is most likely to be at fault.
Steve.
  • tasos
17 Jan 2012 18:20 #31189 by tasos
Replied by tasos on topic Re: ecu....some help
Paul you have absolute right....the fan must work , differently it does not function the a/c.
Steve the pressure checked with a manometer... the a/c compressor is working if i short-circuit the relay.
No cool air will come to the cabin until the a/c compressor start working---->fan problem
  • Paul4x4
17 Jan 2012 19:03 #31191 by Paul4x4
tasos wrote: Paul you have absolute right....the fan must work , differently it does not function the a/c.
Ok, if the compressor doesn't turn on like it should, then the fan relay might be broken. In the wiring diagram it shows that ecu gives a signal to the fan relay, and then the fan relay activates the compressor relay. But if the fan relay is ok, the problem might be in the ecu after all. :blink:
  • 247sniper
17 Jan 2012 20:44 - 17 Jan 2012 20:45 #31202 by 247sniper
Sorry I read your post wrong.
Can you post or pm me the wiring diagram, and I can advise you from there.
Steve
Last edit: 17 Jan 2012 20:45 by 247sniper.
Time to create page: 0.120 seconds
