Uprated Battery ??
28 Nov 2011 16:54 #26791
by facade
You need a battery tender as the Americans call them, the battery is discharging due to the alarm etc.
Optimate is one of the best around.
You could use a solar charger, but they don't work very well
Replied by facade on topic Re: Uprated Battery ??
Gromit wrote: The standard battery on mine struggles as I only use it at weekends
- TomDK
28 Nov 2011 20:49 - 28 Nov 2011 20:50 #26832
by TomDK
Replied by TomDK on topic Re: Uprated Battery ??
also consider Exide Maxxima Dual AGM. As good as Optima but slightly cheaper.
www.tayna.co.uk/Exide-EP450-DUAL-AGM-Bat...-MAX900DC-P7502.html
Or this,
www.battery2u.co.uk/EP900-exide-leisure-battery.aspx
Or this,
Last edit: 28 Nov 2011 20:50 by TomDK.
28 Nov 2011 22:35 #26844
by kirkynut
Mine has been on it's side plus a little and didn't leak!
Replied by kirkynut on topic Re: Uprated Battery ??
Obarno wrote: Having said that I think the Numax is an excellent all round battery although perhaps one that doesn't like to be inverted!
29 Nov 2011 08:41 #26857
by Obarno
Replied by Obarno on topic Re: Uprated Battery ??
I guess you were both lucky and unlcky Kirkynut! Lucky the battery didn't leak, but unlucky to find out the way you did!
29 Nov 2011 09:27 #26865
by kirkynut
They were originally designed for Marine work where they are tipped all over the shop, so they have been made not to leak. So there is no reason for them to do so really.
Don't think of them like the battery you'd get in Halfords!
- Gromit
29 Nov 2011 11:02 #26879
by Gromit
Replied by Gromit on topic Re: Uprated Battery ??
Bloody hell, I just meant a battery with a bit more beef !, not gonna part with over £100 for a friggin battery (tight Yorkshireman) !!!!!
