Uprated Battery ??
29 Nov 2011 16:45 #26892 by kirkynut
Replied by kirkynut on topic Re: Uprated Battery ??
That's why I went for Numax!!!
  • jonesyba420
11 Nov 2013 09:22 #90342 by jonesyba420
Replied by jonesyba420 on topic Re: Uprated Battery ??
what numax did you go for kirky?
  • helijohn
11 Nov 2013 18:25 #90431 by helijohn
Replied by helijohn on topic Re: Uprated Battery ??
kirkynut wrote: They were originally designed for Marine work where they are tipped all over the shop, so they have been made not to leak. So there is no reason for them to do so really.
Don't think of them like the battery you'd get in Halfords!
I don't even consider a Halford's battery!! :laugh: :laugh:
  • jonesyba420
14 Nov 2013 09:22 - 14 Nov 2013 09:28 #91058 by jonesyba420
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationwill either of these fit my jimny?(in the standard position) i think the stock jimny one is only 35amp so these would seem to be an upgrade.
Last edit: 14 Nov 2013 09:28 by jonesyba420.
  • helijohn
14 Nov 2013 10:00 #91062 by helijohn
jonesyba420 wrote: will either of these fit my jimny?
I admit I ain't looked carefully but does the Jimny not have smallish terminals, I have often had to change the Suzuki terminations to use alternative batteries. The larger one might be the same as the smaller on the new battery?
  • jonesyba420
14 Nov 2013 10:11 #91067 by jonesyba420
the jimny does have small terminals but its only a case of changing the connectors on the leads. just curious if anyone had either of those,dont want to spend out to then find it doesnt fit in the hole! they both recon there compatible with a jimny but then it is ebay so they might just say that :laugh:
Time to create page: 0.198 seconds
