rocklobster box
- r_ogilvy
06 Nov 2011 19:55 #25273
by r_ogilvy
rocklobster box was created by r_ogilvy
i have just put 31 inch tyres on my jimny, iv been out in it today and its been fine, iv heard alot about the rocklobster transfer box, what is the benifits from this and is it worth doing?
- supergaz
06 Nov 2011 20:24 - 06 Nov 2011 20:24 #25277
by supergaz
Replied by supergaz on topic Re: rocklobster box
www.bigjimny.com/images/documents/rocklobster.pdf
Martins guide explains it all.
I'm running 235/75/15 special tracs so not much difference to yours, I find off road when it comes to sticky stuff or hills (no power going up) or no engine braking going down, also as the low range gearing is to high you will be slipping the clutch and using more revs to get anywhere, so you will be changing the clutch very often.
I am fitting a low range transfer box soon and it will be well worth every penny spent.
Last edit: 06 Nov 2011 20:24 by supergaz.
- vitara_mad
06 Nov 2011 21:11 #25282
by vitara_mad
Replied by vitara_mad on topic Re: rocklobster box
its well worth fitting a lobster box they transform the jimny into a much more capable motor offroad & gives you better gearing on road with big tyres
worth every penny you won't regret it
- TomDK
06 Nov 2011 21:41 #25283
by TomDK
Replied by TomDK on topic Re: rocklobster box
but wouldn't the 25% reduction offered by JimnyBits be a cheaper solution if you're not doing 100% hardcore offroad?
- r_ogilvy
07 Nov 2011 07:36 #25292
by r_ogilvy
Replied by r_ogilvy on topic Re: rocklobster box
Now your saying that I did have to drop down gear on the road going up hills, can you buy the rocklobster anywere rather than building one?
Seeing the comments it looks worth doing, I'm not keen on building one tho,
If anyone has one for sale, let me no, I would be very intrested.
Off the topic, have you had anything to do with a kam locker, or the 200quid lockright kits?
- darthloachie
07 Nov 2011 12:23 - 07 Nov 2011 12:24 #25302
by darthloachie
Replied by darthloachie on topic Re: rocklobster box
Offroad armoury can supply one complete
Rockwatt can build you one but I think you have to supply the 410 and 413 transfer boxes - you can pm him on here
Rob Storr used to do them but i dont know if he is still in business as i can't find his website anymore
They do pop up on ebay so watch there
Kamlockers are supposed to be good - they are electrically operated so can only be swtiched on when you need it
we have a lockright one on nthe back of ours - it is pretty effective but it is perminently working so you get some clunks as it dis-engages for sharper corners but you soon get used to it
there are also ARB air actauted lockers which are very good but expensive by the time you have added a compreessor to operat it
Last edit: 07 Nov 2011 12:24 by darthloachie.
