Chassis clearance
- aniesigh
03 Nov 2011 20:34 #25113
by aniesigh
Chassis clearance was created by aniesigh
Hi all,
could someone with a standard (ish) height jimny let me know the clearance between the ground and the bottom of the chassis rails at the lowest point?
cheers
Adam
cheers
Adam
- aniesigh
05 Nov 2011 20:05 #25213
by aniesigh
Replied by aniesigh on topic Re: Chassis clearance
anyone? pleassseeee
doesnt matter if its not standard height just let me know roughly how much its been lifted
- ZookFastback
06 Nov 2011 06:27 #25221
by ZookFastback
Replied by ZookFastback on topic Re: Chassis clearance
At a point midway between the rear of the front radius arm and the front of the rear radius arm, my chassis is 260mm of clearance. Its a Santana Suzi soft top.
Standard suspension components 11 years old.
Why? :silly:
Why? :silly:
- aniesigh
06 Nov 2011 09:43 #25224
by aniesigh
Brilliant thans
just trying to work out what height my truck will run, need to decide where to put axle link brackets.
thanks again
thanks again
- Blakey
06 Nov 2011 11:17 #25230
by Blakey
Replied by Blakey on topic Re: Chassis clearance
Mines running lj78 axles, 3" ORA lift kit and 37" Swampers and I have got about 20" but its not got any weight in it as yet so will probally loose 2" or more when its got all the bits in it. Hope this helps
- X-Eng Simon
06 Nov 2011 11:37 #25232
by X-Eng Simon
Replied by X-Eng Simon on topic Re: Chassis clearance
Blakey - got any photos? It would be interesting to see how you have approached it? My swampers measure 36.5" and I've needed to move each axle 100mm further out. Clearance under the mid point of the chassis rails is 400mm without any gas in the Fox Air Shox - so I guess about 500 with.
Si
Si
