Chassis clearance
  • aniesigh
06 Nov 2011 11:41 #25233 by aniesigh
Replied by aniesigh on topic Re: Chassis clearance
Cheers both! Glad you're putting those axles to good use Si ;) my boggers are 36.5" too, havent settled on an axle location as yet. from seing Blakeys build on Devon4x4 forum he's using an ORA Assasin body so maybe doesnt need as much clearance as you Si?
cheers
Adam
  • X-Eng Simon
06 Nov 2011 11:50 #25235 by X-Eng Simon
Replied by X-Eng Simon on topic Re: Chassis clearance
Have you got a link?
My mission for today is finishing welding the front axle A frame (for single link) and fit an LJ70 steering box - which is looking like it might take a bit more metalwork than I'd figured! I'll post piccies later. Just stopped for some lunch!
Si
  • aniesigh
06 Nov 2011 11:53 #25236 by aniesigh
www.devon4x4.com/index.php?option=com_ku...itstart=20&Itemid=81
whats the link for your thread simon? i found it before but cant find it now :unsure:
  • Blakey
06 Nov 2011 12:48 - 06 Nov 2011 12:51 #25237 by Blakey
Replied by Blakey on topic Re: Chassis clearance
With using the assasin body clearance is not a real issue just got to move the front axle enough foward so the tyres dont touch the bulkhead, have moved the rear axle back 70mm and using the ORA rear radius arms for the front so should move it far enough foward. I think it the end i may losse a bit of clearance as have got to add winch, 3x batts, fuel, seats and other bits.
I was looking at using the lj steering box instead of moving the standard one foward but am know looking at hydro steer and using the kit from Rob at ORA
Last edit: 06 Nov 2011 12:51 by Blakey.
  • X-Eng Simon
06 Nov 2011 13:53 - 06 Nov 2011 14:31 #25238 by X-Eng Simon
My build is here : Jimny with Toyota 80 Axles
I've not updated it for a while as most of what I've done recently are small fiddly time consuming bits that don't look any different once they're done!
The LJ steering box could have been made to fit on to a Jimny. Granted the bolt holes are in inconvenient places but in the only place it fits, it puts the end of the pitman arm in the ideal location for the axle being 100mm further forward - with 80 series Axles anyway!
Why did you go for 70 series axles instead of 80? They are harder to find and sell for similar money - and don't have lockers as standard. I guess you must have a good reason?
Si
Last edit: 06 Nov 2011 14:31 by X-Eng Simon.
  • Blakey
06 Nov 2011 15:30 #25241 by Blakey
Went for the 70 series as i manged to get both axles and props for £250. The 70's ones are bit narrower and are a bit lighter than the 80 series. The ones i got are from the LJ78 that come with the rear disk brakes as standard. With the lockers i am at present going to go open diffs and fiddles brakes and maybe ARB lockers once i have used it on a few events and seen how it goes.
Time to create page: 0.107 seconds
