Replacing air hub pipes with silicone hose.
  • trextr7monkey
02 Oct 2011 11:37 #22909 by trextr7monkey
Replied by trextr7monkey on topic Re: Replacing air hub pipes with silicone hose.
Not an expert on this by any means but wouldn't nylon air line tube - designed for high pressures, be better suited and possibly cheaper than silicon for this job?
atb
Mike
  • Fuzzoire
02 Oct 2011 15:33 #22923 by Fuzzoire
I am no expert either and your dead right, Nylon tubing it is way cheaper than silicone. As I understand there is no air actually being blown down the tube, it is being sucked causing the vacuum which would potentially collapse the tube which is why I initially thought of vacuum hose. Not sure what material the flexible portions of the stock system are?
  • viciouspenguin
02 Oct 2011 15:58 - 02 Oct 2011 15:58 #22924 by viciouspenguin
Replied by viciouspenguin on topic Re: Replacing air hub pipes with silicone hose.
why not fit manual hubs? :P
Last edit: 02 Oct 2011 15:58 by viciouspenguin.
  • Fuzzoire
02 Oct 2011 16:25 #22926 by Fuzzoire
My missus wouldn't thank me for that in the snow. Besides I quite like the clonk, clonk and the click, click (when it works).
02 Oct 2011 20:15 #22943 by facade
I copied my pipes in copper brakepipe: took ages to make and braze on the tee pieces, but you can buy ready made tee pieces for brakepipe if you have a flaring tool..
You could use microbore heating pipe if it is still available, there must be solder tee pieces available.
02 Oct 2011 20:44 #22947 by dirtydogz
Yes you can still get microbore heating pipe from screwfix
www.screwfix.com/c/heating-plumbing/poly...lene-pipe/cat2330006
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Time to create page: 0.465 seconds
