Replacing air hub pipes with silicone hose.
  • goatboy
10 Oct 2011 13:10 #23418 by goatboy
Thats not the standard route is it?
Mine go a completely different way... :dry:
10 Oct 2011 13:42 #23421 by mlines
Yours should drop down onto the Diff in the centre of the axle if they are routed normally, this makes for a shorter "flex" in the system.
Very early Jimnys drop them onto the Leading arms.
  • jimny extreme
18 Oct 2011 14:16 - 18 Oct 2011 14:16 #23931 by jimny extreme
Replied by jimny extreme on topic Re: Replacing air hub pipes with silicone hose.
i don't see why either the silicone or copper or a mix of the two wouldn't work, only advice I'd give is don't fix them to the leading arm with tywraps try to keep the screw fixing. One of mine had broken and i put a tywrap round it but it got broken on the first outing.
cheers,
John
I used 4mm or 3/16 which ever that they use for some lorry air brakes worked a treat and i re routed it so i dint have to tirap it to the leading arm as both my bols were snapped off in the hole long ago. works a treat never had any problems since.
Last edit: 18 Oct 2011 14:16 by jimny extreme.
  • jimny extreme
18 Oct 2011 14:18 - 18 Oct 2011 14:20 #23932 by jimny extreme
Johnniehec wrote: i don't see why either the silicone or copper or a mix of the two wouldn't work, only advice I'd give is don't fix them to the leading arm with tywraps try to keep the screw fixing. One of mine had broken and i put a tywrap round it but it got broken on the first outing.
cheers,
John
I used 4mm or 3/16 which ever that they use for some lorry air brakes worked a treat and i re routed it so i dint have to tirap it to the leading arm as both my bols were snapped off in the hole long ago. works a treat never had any problems since..
like john said earlier on in this post tiraps to the leading arm are not the way forward.
Last edit: 18 Oct 2011 14:20 by jimny extreme.
  • Laminak
17 Jul 2012 12:57 #44330 by Laminak
Hi Guys B)
What do you think about vaccum silicone hose?
www.auto-performance.co.uk/product_info....9_91&products_id=568
Is it good for the replacement of the "HOSE, SPINDLE VACUUM 4WD" ?
Do you use 3mm hose ?
Thanks for your help B)
  • Sponnie
17 Jul 2012 19:27 #44389 by Sponnie
Replied by Sponnie on topic Replacing air hub pipes with silicone hose.
Jo King's 'upgrade' has been 100% reliable for me.
Time to create page: 0.240 seconds
