Replacing air hub pipes with silicone hose.
- Fuzzoire
01 Oct 2011 20:03 #22884
by Fuzzoire
Replacing air hub pipes with silicone hose. was created by Fuzzoire
Hi,
My air hub pipes have corroded through completely and it's looking pretty costly to replace them. I am wondering if anyone has successfully replaced the steel pipes with silicone hose at a fraction of the cost. I know most advise binning the air hubs for manual versions but I do not wish to do so.
My Jimny is a 2000 X reg with a M13a 1328cc DOHC engine.
For the sake of £10-15 I am going to give it a go. Just looking for a bit of advice or encouragement.
- p1ngu32
01 Oct 2011 20:25 #22886
by p1ngu32
Replied by p1ngu32 on topic Re: Replacing air hub pipes with silicone hose.
There is no reason why it wouldnt work, only drawback might be that they will be more likely to get caught on some thing and ripped off. You could use standard copper brake line to make up the straight sections, and silicone for the joints on to the suspension arms, might make them a little more sturdy, and shouldnt be too costly.
- Fuzzoire
01 Oct 2011 20:38 #22888
by Fuzzoire
Replied by Fuzzoire on topic Re: Replacing air hub pipes with silicone hose.
I thought about using copper brake piping but I am not sure what to do where the single pipes from the solenoids split into two off to each wheel. I was going to to use a nylon t-junction connector with the silicone hose.
01 Oct 2011 21:24 #22891
by MigCooper
Snorkel and plenty of rust to be treated
Replied by MigCooper on topic Re: Replacing air hub pipes with silicone hose.
Yes any T junction will do ... I have redone mine and will create a schematic when I get a chance .... Off to bed now ... :silly:
- viciouspenguin
02 Oct 2011 05:59 #22895
by viciouspenguin
Replied by viciouspenguin on topic Re: Replacing air hub pipes with silicone hose.
Might the silicon tube collapse due to the vacuum?
- Fuzzoire
02 Oct 2011 06:14 #22896
by Fuzzoire
Not sure about it collapsing, it is sold as vacuum hose. MigCooper has apparently done it. Found a shop on ebay selling 3mm for £1.55 a metre free p+p.
Time to create page: 0.381 seconds
