Replacing air hub pipes with silicone hose.
03 Oct 2011 03:54 #22951
by facade
Replied by facade on topic Re: Replacing air hub pipes with silicone hose.
The pipe I'm thinking of is copper, and from hazy memory, about 10mm diameter.
Ordinary brakepipe with threaded tee pieces is one solution, but I'm fairly sure nylon pipe will do the job.
03 Oct 2011 06:48 - 03 Oct 2011 08:19 #22955
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: Replacing air hub pipes with silicone hose.
OK10MM copper pipe off ebay, you can get it for screwfix as well.
compare.ebay.co.uk/like/370259964667?var...ceItemTypes&var=sbar
2002 JLX Soft Top
Last edit: 03 Oct 2011 08:19 by dirtydogz.
- Fuzzoire
03 Oct 2011 07:19 #22960
by Fuzzoire
Replied by Fuzzoire on topic Re: Replacing air hub pipes with silicone hose.
I've bought 4mm silicone vacuum hose now with nylon t-juntions and straight connectors to use at the stock flexible tubing at the hubs. It was the t-junctions that swayed me away from copper as I don't have a flaring tool.
03 Oct 2011 08:20 #22961
by dirtydogz
2002 JLX Soft Top
OK mate good luck.
2002 JLX Soft Top
- Johnniehec
- Thank you received: 56
03 Oct 2011 09:08 #22968
by Johnniehec
Replied by Johnniehec on topic Re: Replacing air hub pipes with silicone hose.
i don't see why either the silicone or copper or a mix of the two wouldn't work, only advice I'd give is don't fix them to the leading arm with tywraps try to keep the screw fixing. One of mine had broken and i put a tywrap round it but it got broken on the first outing.
cheers,
John.
cheers,
John.
- Fuzzoire
08 Oct 2011 17:50 #23271
by Fuzzoire
Hi everyone, successfully used silicone vacuum hose today. The actual vacuum created is tiny compared to the specifications of the hose. I only needed to replace the section that runs over the front axle and it would have been incredibly easy if the hub release solenoid VSV1 hadn't been busted too. After testing for hours to find the problem I can now engage 4wd from inside the car but have to pop the bonnet and use the release hose direct off the engine to get back to 2wd. Any ideas as to how much the solenoids are anyone?
Time to create page: 0.309 seconds
