Diff/pinion bearing replacement.
  • mcjimny
26 Sep 2011 13:14 #22577 by mcjimny
Diff/pinion bearing replacement. was created by mcjimny
Has anybody had to do this? If so whats the spanner level like for DIYing it?
I just MOT'd mine and its got an advisory for it. I knew there was play there and its on the list to look at anyway. Ideally i would like to get it done before winter.
As usual any help is appreciated.
26 Sep 2011 15:08 #22585 by facade
6 spanners and a socket set if you haven't done it before.
Get another differential and swap it over.
You have to correctly set the pinion bearing preload, adjust the mesh of the crownwheel and preload it.
Most likely if the pinion bearings have gone the crownwheel and pinion will have wierd wear patterns and be as noisy as hell.
Going rate is about £75 for a good diff from a breakers, you won't change the bearings and crush spacer for that.
  • vitara_mad
26 Sep 2011 15:09 - 26 Sep 2011 15:11 #22587 by vitara_mad
Replied by vitara_mad on topic Re: Diff/pinion bearing replacement.
changing the bearings is not a difficult job to do its just you have to make sure you set the diff back up right or you will destroy the diff in a short space of time
as above getting a replacement diff is the easyest & prob the cheapest option & i know where theres one for sale too :P
Last edit: 26 Sep 2011 15:11 by vitara_mad.
  • mcjimny
26 Sep 2011 16:00 #22590 by mcjimny
Replied by mcjimny on topic Re: Diff/pinion bearing replacement.
They've marked it as dangerous on the advisory note. Presumably i can keep going until the diff eats itself if i use 4wd? I've not got the money for a few weeks to get a replacement unfortunately.
As i've never touched a diff before is it as simple as pulling the shafts, removing the prop and unbolting the diff?
  • vitara_mad
26 Sep 2011 16:24 #22591 by vitara_mad
mcjimny wrote: They've marked it as dangerous on the advisory note. Presumably i can keep going until the diff eats itself if i use 4wd? I've not got the money for a few weeks to get a replacement unfortunately.
you also need to undo the brake pipes from the rear wheel cylinders to pull the shafts out
its a easy job to replace a diff
  • mcjimny
26 Sep 2011 16:38 #22592 by mcjimny
Its the front - i should have said :blush: It'll be part of other jobs as i'm taking it all apart, i know the discs will need doing next time i do the pads and the kingpins (again :pinch: ) so may as well do it all together.
Time to create page: 0.284 seconds
