Tow Bar
- adamatdraycott
16 Aug 2011 04:25 - 16 Aug 2011 05:33 #20414
by adamatdraycott
Replied by adamatdraycott on topic Re: Tow Bar
1.3 tonne braked, something like 800kg unbraked?
I have a witter detachable, looks great and works great, but i too have bent the lecy braket more than once. I'll get round to having a heavy duty stainless one made at some point!
Mud doesn't seem to be an issue in the removable mechanism, dust and water is though.
Last edit: 16 Aug 2011 05:33 by adamatdraycott.
- ZookFastback
16 Aug 2011 05:24 #20415
by ZookFastback
Replied by ZookFastback on topic Re: Tow Bar
I use a Hayman Reece Hitch. The sticker on it says it is "Rated 2,500kg". If I need to tow someone out of a bog I remove the hitch tongue from the towbar and put the pin back in, through the loop of the tow belt. I am not much in favour of snatch straps (Kinetic energy) because they seem to lose their stretchability after 5-6 heavy recoveries.
The manual that came with my Jimny says towing capacities are 550kg unbraked, 1,100kg braked.
I use a Tekonsha electric brake controller and fitted electric operated disk brakes to my 690kg "Cabana" caravan and electric operated drum bakes to my small yacht trailer.
- mcjimny
16 Aug 2011 06:53 #20422
by mcjimny
Replied by mcjimny on topic Re: Tow Bar
1300kg braked and a measly 350kg i've always seen but even a quick google shows varying figures.
- ZookFastback
16 Aug 2011 07:36 #20425
by ZookFastback
Here is what is written down on page 7.1 of my original manual, which I have since replaced with a Haynes manual.
Quote
"Your SUZUKI was originally designed to be capable of towing a trailer which does not exceed the following towing capacity:
Towing Capacity
(Trailer, Cargo & Tow bar)
Braked trailer: 450 kg ( 1000 lb)
Unbraked trailer: 350 kg ( 770 lbs)
However, some countries have regulations which specifically allow trailer weights greater than the capacities shown above; vehicles sold in these countries have towing capacities which match the maximum trailer weight permitted."
Unquote
This is the sticker on drivers' door edge, showing the max in kgs, 1100 and downforce max of 75.
Australian Design Regulations waffle on a lot but basically say that a vehicle may tow up to it's own weight braked. and 30% unbraked.
What they allow in the UK is any bodies guess
Quote
Towing Capacity
Unquote
- ooky_123
16 Aug 2011 08:03 #20432
by ooky_123
Replied by ooky_123 on topic Re: Tow Bar
I mounted my Topbar electrics to the rear door. here, the socket is 10cm above the top of the bumper, with the wiring passing though the rubber cable duct into the off side inner wing.
So unless I reverse into deep water, there is no way its going to get mudded up.
I use a 1 meter coiled extension cable to connect to a trailer
- Adamski
16 Aug 2011 16:30 #20472
by Adamski
This is what it says on parkers.com but it is wrong
The Jimny tow's:
450kg braked
350kg unbraked
I regularly tow something 320kg and it copes pretty well but I wouldn't like to tow something 450kg long distances. Anything over 450kg would technically be illegal and I dont know what the punishment would be. I suppose if you were a chav you would get a slap on the wrist but an upstanding citizen would probably get 12 points and a £20k fine
Replied by Adamski on topic Re: Tow Bar
mcjimny wrote: 1300kg braked and a measly 350kg i've always seen but even a quick google shows varying figures.
The Jimny tow's:
450kg braked
350kg unbraked
Time to create page: 0.221 seconds
