Installing an Amp..?
- lukeyblunt
27 Jul 2011 17:54 #19591
by lukeyblunt
Installing an Amp..? was created by lukeyblunt
Hi Everyone,
Just bought this tiny amp .. and i don't have a clue what any of the wires do and where they need to go.
I've seen a lot of video tutorials.. but on there.. it seems each wire has a seperate port- whereas this one is just one plug with multiple wires..?
What the ... :blink: ..?!
I also cant make any sense of the instruction leaflet. Sorry to be a nuisance.
Any help is appreciated! Many thanks
Attachment ampclose.png not found
Attachment ampwires.png not found
27 Jul 2011 18:38 #19596
by facade
Replied by facade on topic Re: Installing an Amp..?
The diagram on the case shows that there are 4 speaker pairs labelled 1 left & right and 2 left & right
The red with the fuse is likely power in, black will be earth.
No idea what it is supposed to do so can't help with any other wires, could be trigger in from a preamp, mute in from a phone, preamp power out.....
Can't see any inputs either..
What do you need it for?
- lukeyblunt
27 Jul 2011 18:45 #19600
by lukeyblunt
Replied by lukeyblunt on topic Re: Installing an Amp..?
Thanks for your response. I bought a 500W underseat sub which didnt fit under the seat, so i'm selling that.
But for now, i figured i'd plum it all in then fit the sub when i get it.
27 Jul 2011 18:53 #19602
by facade
That is not the right amp for a sub, a sub is only a single channel, although some systems run a pair of subs. You can bridge the amps to double the power, but you need 8 ohm speakers then.
Looks like a 4 channel power amp, but not much power, I bet your radio is more powerful than that.
Don't know much about car audio I'm afraid
- doncarlyon
27 Jul 2011 19:13 #19603
by doncarlyon
Replied by doncarlyon on topic Re: Installing an Amp..?
Does the amp have any settings for high/low pass filters?
What inputs are you going to use?
- lukeyblunt
27 Jul 2011 19:22 #19604
by lukeyblunt
there are some high and low filters... but i have no idea what anything does.
is it worth just calling a sparky..?! :blink:
Attachment ampback.png not found
Time to create page: 0.160 seconds
