Diagnostic Trouble Codes and Reader
11 Apr 2011 18:52 #14840
by kirkynut
Diagnostic Trouble Codes and Reader was created by kirkynut
I have got the same scan tool and gauge that Martin has - the Maxi Trip unit:
www.bigjimny.com/index.php?option=com_co...accessories&Itemid=2
Yesterday I went through some water - nothing too bad and just as I had climbed out of it - in the Jimny obviously - it stopped with a jar as the engine stopped and I was in low first in the Rocklobster.
I got it started and got out of the course but it was barely running.
I turned it off and then got it to idle and run ok.
I ran my scan tool and got code 335 - this tells me that the Crank Shaft Sensor stopped speaking to the ECU for over 2 second.
It ran fine then though and I cleared the code and its fine now, so I guess a little water got in the plug, having been flicked there by the fan and pullies no doubt.
I'll do a bit of waterproofing of the plugs but what a wonderful bit of kit. I knew at an offroad site what the issue was straight away!
I would urge everyone with the twin cam engine to buy one of these and a CD manual and print off the trouble code table to keep in the car like wot I does.
It also tells you your engine temperature to the degree. Mine was getting a tad warm for my liking as I'd blocked the rad with mud (new rad fitted now though) but I wouldn't have known by the factory guage as it did not move.
So I have now prevented a potential head gasket / warped head and know what caused my running issue all myself for the cost of this £100.00 bit of kit.
It also told me my Cat was on the way out last year. It got through the year before but I'd occasionally had a DTC telling me that the readings betweent the 2 lambda sensors was too high, which are either side of the Cat, so it suggested the Cat was on it's way out.
This MOT- the Cat had died! At least I knew it was coming though!
Again, another reason to buy one of these.
Sooooooooo much cheaper than paying a garage to read your codes when the check engine light comes on!
- doncarlyon
11 Apr 2011 19:15 - 11 Apr 2011 19:16 #14842
by doncarlyon
Replied by doncarlyon on topic Re: Diagnostic Trouble Codes and Reader
Last edit: 11 Apr 2011 19:16 by doncarlyon.
- goatboy
12 Apr 2011 13:43 #14887
by goatboy
Replied by goatboy on topic Re: Diagnostic Trouble Codes and Reader
Where is the port exactly where it plugs in?
I had a quick look the other day to try my scanning tool but it wasn't immediately obvious so I gave up :blush:
- Keefe
12 Apr 2011 16:02 #14897
by Keefe
Replied by Keefe on topic Re: Diagnostic Trouble Codes and Reader
If I remeber correctly.
Just below steering wheel to the right.
Kneel down and look up, under the dash. A torch might help if you're outside.
I plugged my reader in and it just sticks on "Trying to Connect"
2001 Tin top with the M13 engine.
Wouldn't mind one of those Maxitrips for mine but unsure if one would work on my Jim.
- Keefe
12 Apr 2011 19:46 #14921
by Keefe
Been in touch with the company and the Maxitrip will not work on mine.
here's his reply:
Hi,
If a code reader will not work with it, nor will the MaxiTrip.
Regards
Mike
Oh well.
here's his reply:
Hi,
Regards
Mike
Oh well.
- doncarlyon
13 Apr 2011 05:40 #14932
by doncarlyon
A few people have had this issue with the scangauge and its just one of the settings needs changed.
Time to create page: 0.248 seconds
