TPMS
18 Jan 2026 08:55 #263445
by 4x4
I'm looking to buy a nearly new set of wheels and tyres from a 2023 Jimny, to fit on my 2016 SZ3. I know they will fit but does anyone know if the TPMS will work or do I need to change the sensors? Is there a reset button on the 2016 SZ3. Usually if the warning light comes on I just sort the pressures and it rights itself.
- Roger Fairclough
- Thank you received: 225
18 Jan 2026 11:34 #263448
by Roger Fairclough
Replied by Roger Fairclough on topic TPMS
If the sensor tells you a pressure is wrong and increasing the pressure to normal cancels the reading ,all is well.
Remember, at this time of the year, you will observe fluctuations pressure due to low air temperature.
Roger
Roger
- Roger Fairclough
18 Jan 2026 18:21 #263453
by Roger Fairclough
If you need to buy a new sensor, for whatever reason, then the cars computer will realise it has a new sensor and act accordingly.
Roger
Roger
18 Jan 2026 18:45 #263454
by fordem
More out of curiosity than anything else (neither of my Jimnies has TPMS), what, in this case, is "accordingly"?
Will it refuse to communicate with the new sensor until it is registered - or - will it recognize the new sensor and "adopt" it without making a fuss?
18 Jan 2026 18:58 - 18 Jan 2026 19:09 #263455
by Gatisk
I don't think this is correct (about to change TPMS). The TMPS system recognizes the sensor after driving a short distance at speeds above 25KM/H (there are no manual nearby, so it's not accurate). If the previous sensors have SUZUKI-compatible "software", then everything will happen automatically after a trip on the highway.
Last edit: 18 Jan 2026 19:09 by Gatisk.
The following user(s) said Thank You: 4x4
Time to create page: 0.154 seconds
