7 inch headlight
- Rogerzilla
- Premium Member
- Thank you received: 15
29 Oct 2024 12:52 #258094
by Rogerzilla
Replied by Rogerzilla on topic 7 inch headlight
I did the headlights on the gen3 with the Philips kit. Almost two hours' fairly hard work, but they came up just like new.
- Thank you received: 667
29 Oct 2024 13:58 #258098
Replied by DrRobin on topic 7 inch headlight
Hi,
I just did the headlights on my 2001 Boxster, but didn't use a kit. One headlight is much older and has a lot more of a dull appearance.
I used fine wet and dry to remove the rough stuff, then Meguiars Ultimate Compound and a polishing machine, then Meguiars Ultimate Polish before sealing it with their wax.
The difference is quite striking, but it took several applications of the compound and polish to achieve a sparkling finish. However, UV light will some make them go dull again, so they will need a UV protective coat or film, I haven't got round to buying this yet.
If your specialist kits include a UV protective coat I would suggest applying it, if not you might as well use ordinary compound/polish.
Other things that are known to work are baking soda and toothpaste, but make sure you get one with a minty flavour to make your lights taste good afterwards [sic].
Robin
Robin
29 Oct 2024 14:05 #258099
I used Osram Nightbreakers in my last Jimny and in my Boxster, but I needed some more for my Boxster as I only installed dip beam (it has H7 bulbs, two per reflector).
I did a search online, Osram make the original Nightbreaker at 150%, but make a new one at 220%, although in a well organised test Philips Racing Vision GT200 pipped both Nightbreakers to be the best halogen bulbs.
The test also compared Halogen and LED and found that a good Halogen has longer reach than LED and doesn't cause as much glare. Whilst I am sure that is true for a LED bulb vs a Halogen in the same reflector (I know they aren't legal here) the LED lights on my SZ5 wouldn't be easily beaten by any Halogen.
Robin
Robin
- Thank you received: 1995
29 Oct 2024 14:21 #258100
Replied by Lambert on topic 7 inch headlight
I didn't really get on with nitebreaker as it's all high beam so I've gone back to ring.
Those frames are exactly what I had in mind thanks
29 Oct 2024 19:13 #258104
by gv42
Replied by gv42 on topic Re:7 inch headlight
We use GT200, as for polishing, using sanding pads ( 300, to 600, 1000, then 3000) then gloss lacquer to seal it , see the results on a audi S5 and it looks new
Sent from my SM-S918B using Tapatalk
14 Nov 2024 02:55 #258292
by crash486
Replied by crash486 on topic Re:7 inch headlight
One of the first things I did when I got my jb74 home, was to apply some ppf I had to the headlights , bonnet edge and a few other high wear points.
It's been 5 years (in a month or so), so I'll report back in another 5 years (hopefully) if the ppf has stopped the headlights from yellowing.
JB74W Australia
JB74W Australia
