7 inch headlight
- Thank you received: 1996
27 Oct 2024 07:01 #258067
7 inch headlight was created by Lambert
So I have noticed that the tops of my headlight outers are starting to cloud. There are various options including buffing or covers at one end of the cost scheme and then like for like replacement or even led replacement at the other end. However I am wondering if it is possible to fit a 7 inch headlight unit like say a trucklite or similar and then have a separate indicator to the side. I'm sure I could do something with some flat abs or similar and pick up existing mount points but it's likely to look odd or incomplete. So to that end I have been looking for a moulded surround and I am struggling to find anything. I might have said print something but I'm not literate enough in that respect. Has anyone seen something available to buy?
27 Oct 2024 21:39 #258070
Replied by yakuza on topic 7 inch headlight
I think I found some japanese ones. But they where wrong sided, like the blinkers and park where on the inside of the 7" so they looked off to me. And they cost way too much.
I just bought a set of used foggy headlights I will polish and replace my cracked ones. The cracked ones Will be models for some sort of 7 inch Brackets when or if I get the time.
27 Oct 2024 21:41 - 27 Oct 2024 21:46 #258071
Now they are on alixpress and still look off. No place for blink or park.
If you Google jb43 7 inch headlight
You may find them in the pictures.
Last edit: 27 Oct 2024 21:46 by yakuza.
29 Oct 2024 07:54 - 29 Oct 2024 07:56 #258087
www.aliexpress.com/item/1005005081014325.html
these look so much better, even possible to buy just the frame and bracket so you can buy correct 7" for your LHD/RHD preference and E-marked instead of the chinese LED wich is most likely not MOT-ok.
Last edit: 29 Oct 2024 07:56 by yakuza.
29 Oct 2024 10:43 #258090
by 300bhpton
The plastic can usually be cleaned up with a little effort the 3M kit works very well: amzn.eu/d/1YFyGkR
I did the headlights on my Camaro with this kit, only take 10 mins or so per headlight.
If you want a 7" round headlight, check these out:
www.banginheadlights.com/products/tradit...riant=42493072834755
I ordered a pair yesterday in fact.
Most LED lamps are horrid with high kelvin (6000k +) tints and horrid blue'ish light, that makes greens & browns (trees/countryside etc) all look rather greyish. plus induce more eyestrain. Many LED units, esp Aliexpress/Amazon produce horrid glare and dazzle oncoming traffic.
Other options would be to go for a good set of Quadoptic or Crystal halogen units an run some good bulbs or some LED bulbs.
www.classiccarleds.co.uk/collections/hea...ariant=8299353243743
Replied by 300bhpton on topic 7 inch headlight
29 Oct 2024 12:03 - 29 Oct 2024 12:04 #258093
totally agree on the LED's, I will be using standard halogen H4 glass and metal inserts and most likely Osram nightbreaker.
The high kelvin white is no good in the snow, you loose the depth. More yellowish light and you will easier see the contours and edges of the road.
The 3M kit is what i used on my Jimny earlier and on the Swift. First time I used it I was way to careful with the grinding, should have gone on for longer but was afraid to not being able to buff them back up. But it was no problem and they have held on for a few years.
Swift was only matte and came out OK.
Last edit: 29 Oct 2024 12:04 by yakuza.
Time to create page: 0.227 seconds
