Pedders Lift Kit - Help
16 Oct 2025 03:33 #262323 by Lambert
Replied by Lambert on topic Pedders Lift Kit - Help
Watch this especially around the 5 minute area. It rather demonstrates that a jimny is somewhat in its own class due to its relative lack of size enabling it to follow different lines than other vehicles.
16 Oct 2025 09:18 #262329 by 300bhpton
Replied by 300bhpton on topic Pedders Lift Kit - Help
That's an old video. But more than anything shows up different drivers, lines and wheelbases. Not really a very good example of lockers vs suspension. Due to the other variables at play.
Not that they are mutually exclusive, you are allowed to have both...
However, as capable as lockers are. They are normally not allowed for trialling, and would ruin your turning circle to the point you likely couldn't drive most courses.
I'd say the same is true for most UK green lanes. While there might be a few extreme exceptions where a locker would be handy. You wouldn't want to drive constantly with the locker(s) in and the fact you already have TCS, means the occasions a locker would be needed are likely few and far between.
What lockers don't do is offer stability. Having 2 wheels in the air can make a vehicle feel horrid to drive, even if the lockers enable it to still turn all the wheels. It is also less comfy with the wheels crashing down impacting the ground.
For what Dr Robin appears to use their vehicle for, I'd personally suggest good suspension would be a much better investment than lockers.
16 Oct 2025 11:42 #262330 by Lambert
My point was more that if you understand your vehicle and have seat time with it and really it's seat time over everything but if you do then even a relatively stock jimny is rarely found wanting. Even within the boundaries of a trial section a jimny has line options that a defender doesn't simply because it's so much smaller. The same is true for me on circuit yes my boys m440i is faster in every way but it needs more real estate and has more gravity to deal with so in reality the gap between us is not as big as the spec sheet might imply. And i also have about 15 years more seat time in my jimny than he does as he doesn't keep a car that long.
16 Oct 2025 12:23 #262332 by Lambert
It's also worth mentioning that to my mind the standard suspension on the gen4 is way too soft, it's OK in town on roads covered by speed bumps and pothole but it can't carry any kind of speed on an open back road. Certainly if I liked bellerophon more she would be getting an upgrade but there's no point that is what temeraire is for.
16 Oct 2025 15:14 #262333 by 300bhpton
Agree completely.
Knowing your vehicle and what can and can't do can give you an edge in any situation. But also you can see where it lacks, thus allow you to enhance or at least address those points.
For trials, I agree the narrow Jimny has line options you may not have in a 90, but an 86 or 80" coiler certainly might. And it does depend on the terrain and vehicles. I've setup lots and lots of trials and competed for over 25 years. We also get quite a few Jimny's at some of our events. Sometimes they do very well, sometimes they don't. The times they don't is when the terrain is, shall we say more technical and severe.
Even the on the milder terrain at the farm, if the Jimny didn't have traction control, it would likely be easier to be stopped than a basic Defender, due to the comparatively less flexy suspension and lower clearances.
I'm really not knocking the Jimny, but being in a lucky position to have access to directly compare mine to stock and modified Land Rover's. I also find it fascinating how they perform differently in different situations. But also the similarities.
I'm also fortunate to have had a stock Jimny and easy access to an off road area to play with it and see how the mods have changed & improved it.
17 Oct 2025 07:58 #262340 by DrRobin
Replied by DrRobin on topic Pedders Lift Kit - Help
Thanks to everyone who replied, it has helped.
I have decided to go for the Pedders kit, it looks like it is going to be right for me based on the following:
- the most frequent place for me to get stuck is resting on the underside, usually the radius arm protectors;
- I have got stuck with approach angle, but that wasn’t entirely the bumper’s fault, it was move underneath at the front. Likewise, I have hit the tow bar before on exit;
- I seldom get stuck on the diffs, most of the stages aren’t deeply rutted and I can pick my line round any that are;
- the Pedders kit gets a good recommendation from James and I like that it also has good road manners.
At 45mm, it’s only 5mm less than other 2” kits, that isn’t even the difference between a new and part worn set of chunky tyres, but does keep you away from hitting the cross member or requiring castor correction etc.
The lift will then also allow me to run taller tyres, although as already pointed out there isn’t much choice for tall skinny tyres.
I had set my sights on Special Track’s (on a spare set of wheels) but 195/80 is really the highest in 15”.
Should I go to 16” and fit 205/80 R16 (I have a spare set of 15” alloys, but a set of cheap steel rims isn’t much)?
My Worm Drives (215/75r15) work out at 27.7” diameter
195/80r15 work out at 27.3” diameter
205/80r16 work out at 28.9” diameter
The knobbly tread might add a bit more on harder surfaces, but still an extra 0.6” of ground clearance under the diffs and body.
I would need to check if they would rub.
