NEW OWNER
3 years 6 months ago #248829 by BALDY60
NEW OWNER was created by BALDY60
hi all, new Jimny owner here, picked up a LCV in blue with black roof   will post pics once i have worked out how.
so far have replaced side marker, high level brake light and front indicators with smoked leds, fitted mud flaps, and removed bulkhead.
i have a question regarding led bulb replacements for the rear lights ( don't fancy the Jimny style ones) any recommendations?
cheers, Baldy
3 years 6 months ago #248831 by DrRobin
Replied by DrRobin on topic NEW OWNER
Hi,
Welcome to the forum and happy motoring with your new Jimny.
LED bulbs can be a bit of a problem, if you are in the UK, you can only fit LED bulbs to the exterior of the car if the fitting is designed for LED. So if it has ordinary filament bulbs installed at the moment chances are it is not suitable for LED and you can't legally fit LED bulbs. You can however, change the light fitting to one designed for LED, provided it is E marked.
A lot of people fit LEDs in to ordinary housings but it might get picked up on a MOT or if you get a random light check.
Robin
3 years 6 months ago #248832 by BALDY60
Replied by BALDY60 on topic NEW OWNER
thanks for the reply DrRobin, and thanks for the welcome, i will look into this further.
3 years 6 months ago #248836 by Soeley
Replied by Soeley on topic NEW OWNER
Hello and welcome. I didn't think there was an issue with fitting LEDs in the rear housings as beam pattern doesn't come into them? Indicators might need a resistor in them to make them flash properly.
Time to create page: 0.096 seconds
